[mapserver-users] Change the distance of GRID labels from margins
Pedro Venâncio
pedrongvenancio at gmail.com
Tue Feb 2 04:49:02 PST 2016
Hi Ambrogio,
Thanks for the help! I used a combination of the OFFSET and POSITION. With
that, the X coordinate is relatively well adjusted at the top north and
south . However, for the Y coordinate, I just can adjust for the left or
the right margin, because if I offset for the left, the left coordinate
label is sectioned. We can not hide the coordinates of some of the sides,
right? For example, for Y coordinate only appear on the right side?
Best regards!
Pedro
No dia sábado, 30 de janeiro de 2016, Ambrogio Foletti <afoletti at gmail.com>
escreveu:
> Hello Pedro,
> you can set an OFFSET for the LABEL.
> If you want the label to be further into the map, set it to
> OFFSET 0 -X
> where X is the number that seals the deal for you :)
> Cheers,
> A. Foletti
> 2016-01-21 22:45 GMT+01:00 Pedro Venâncio <pedrongvenancio at gmail.com>:
>> Hi,
>> Is there any way to set the distance of the GRID [0] labels, so that the
>> labels be more spaced from the map margins?
>> [0] http://mapserver.org/mapfile/grid.html
>> I would like to have the coordinates further into the interior of the map.
>> Thank you very much!
>> Best regards,
>> Pedro
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160202/50194fa3/attachment.html>
