[mapserver-users] WMS call with layer names containing a space.
TC Haddad
tchaddad at gmail.com
Thu Feb 4 08:39:32 PST 2016
When querying the TIGER server directly from a browser, the first and third
styles of request both work, while the option with the "+" does not. So
those are the 2 options the server will accept.
I guess Mapserver prefers no space in a name, or a "+" to designate space,
so you might be stuck.
As a best practice, they really should have the version with a space in the
Title rather than the Name, but you can't fix that from your end.
On Thu, Feb 4, 2016 at 7:50 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> All,
> I’m trying to use this WMS:
> http://tigerweb.geo.census.gov/arcgis/services/TIGERweb/tigerWMS_ACS2015/MapServer/WMSServer?
> Specifically, two layers, “Census Tracts” and “Census Tracts Labels”
> I can open the service in just about everything, except Mapserver as a WMS
> client. I’m assuming the problem is in how MapServer is sending it’s
> request.
> I must be missing something obvious.
> Thanks.
> bobb
> Call1:
> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census
> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census>
> Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Censu+Tracts&_OLSALT=0.48749308905327293&SRS=EPSG:200068&BBOX=550022.0283237,145619.55953757,593285.9716763,164199.44046243&WIDTH=971&HEIGHT=417>
> error:
> Parameter ‘layers’ contains unacceptable layer names
> Call2 (use “+” for space):
> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census+Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census+Tracts&_OLSALT=0.8675355401581306&SRS=EPSG:4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865>
> error:
> Call3 (URL encoding “%20” ):
> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census%20Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census%20Tracts&_OLSALT=0.8675355401581306&SRS=EPSG:4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865>
> error:
> ##Mapfile
> MAP
> STATUS ON
> LAYER
> NAME "Census Tracts"
> TYPE RASTER
> STATUS DEFAULT
> CONNECTION "
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "Census Tracts"
> "wms_server_version" "1.1.1"
> #"wms_server_version" "1.3.0"
> "wms_format" "image/png24"
> "ows_title" "Census Tracts"
> #"gml_include_items" "all"
> END
> PROJECTION
> "init=epsg:4326"
> END
> TEMPLATE "dummy"
> END #layer
> ##CONFIG "MS_ERRORFILE" "/tmp/trying2.txt"
> ##DEBUG 5
> END
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160204/a148f737/attachment.htm>
More information about the MapServer-users
