[mapserver-users] WMS call with layer names containing a space.
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Feb 4 09:19:31 PST 2016
I was just reading a recent discussion on this, might be the same
discussion
(http://osgeo-org.1560.x6.nabble.com/Allowing-spaces-in-layer-names-WMS-WFS-td5213960.html).
Bob can you file a little test case for this (tiny mapfile, commands to
use to test), as a new ticket on the MapServer tracker?
https://github.com/mapserver/mapserver/issues I can't find an existing
ticket, so we might as well record one.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-02-04 12:51 PM, TC Haddad wrote:
> This came up last year and I don't know if it was ever resolved:
> https://lists.osgeo.org/pipermail/mapserver-users/2014-August/076870.html
> https://lists.osgeo.org/pipermail/mapserver-users/2014-August/076886.html
> On Thu, Feb 4, 2016 at 8:44 AM, Basques, Bob (CI-StPaul)
> <bob.basques at ci.stpaul.mn.us <mailto:bob.basques at ci.stpaul.mn.us>> wrote:
> I was hoping there might be some tricky way of fooling MapServer by
> encoding, etc.
> bobb
>> On Feb 4, 2016, at 10:39 AM, TC Haddad <tchaddad at gmail.com
>> <mailto:tchaddad at gmail.com>> wrote:
>> When querying the TIGER server directly from a browser, the first
>> and third styles of request both work, while the option with the
>> "+" does not. So those are the 2 options the server will accept.
>> I guess Mapserver prefers no space in a name, or a "+" to
>> designate space, so you might be stuck.
>> As a best practice, they really should have the version with a
>> space in the Title rather than the Name, but you can't fix that
>> from your end.
>> On Thu, Feb 4, 2016 at 7:50 AM, Basques, Bob (CI-StPaul)
>> wrote:
>> All,
>> I’m trying to use this WMS:
>> http://tigerweb.geo.census.gov/arcgis/services/TIGERweb/tigerWMS_ACS2015/MapServer/WMSServer?
>> Specifically, two layers, “Census Tracts” and “Census Tracts
>> Labels”
>> I can open the service in just about everything, except
>> Mapserver as a WMS client. I’m assuming the problem is in how
>> MapServer is sending it’s request.
>> I must be missing something obvious.
>> Thanks.
>> bobb
>> Call1:
>> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census>Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Censu+Tracts&_OLSALT=0.48749308905327293&SRS=EPSG:200068&BBOX=550022.0283237,145619.55953757,593285.9716763,164199.44046243&WIDTH=971&HEIGHT=417>
>> error:
>> Parameter ‘layers’ contains unacceptable layer names
>> Call2 (use “+” for space):
>> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census+Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census+Tracts&_OLSALT=0.8675355401581306&SRS=EPSG:4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865>
>> error:
>> Call3 (URL encoding “%20” ):
>> http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census%20Tracts&_OLSALT=0.8675355401581306&SRS=EPSG%3A4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865
>> <http://gis.ci.stpaul.mn.us/datasets/BOUNDARIES/CENSUS/TRACTS/census_tracts_wms.map?FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Census%20Tracts&_OLSALT=0.8675355401581306&SRS=EPSG:4326&BBOX=-93.239,44.892,-92.977,44.993&WIDTH=1557&HEIGHT=865>
>> error:
>> ##Mapfile
>> MAP
>> STATUS ON
>> LAYER
>> NAME "Census Tracts"
>> TYPE RASTER
>> STATUS DEFAULT
>> CONNECTION
>> "http://tigerweb.geo.census.gov/arcgis/services/TIGERweb/tigerWMS_ACS2015/MapServer/WMSServer?"
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_srs" "EPSG:4326"
>> "wms_name" "Census Tracts"
>> "wms_server_version" "1.1.1"
>> #"wms_server_version" "1.3.0"
>> "wms_format" "image/png24"
>> "ows_title" "Census Tracts"
>> #"gml_include_items" "all"
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> TEMPLATE "dummy"
>> END #layer
>> ##CONFIG "MS_ERRORFILE" "/tmp/trying2.txt"
>> ##DEBUG 5
>> END
