[mapserver-users] Rendering of Symbols outside map window
Ambrogio Foletti
afoletti at gmail.com
Thu Feb 11 12:54:31 PST 2016
Hello Patrick,
if you are using PostGIS as datasource, I would solve the problem by
integrating a st_buffer in the DATA element itself ;) The added bonus is
that you will get the attribute values from a GetFeatureInfo (if
implemented) in the whole buffer zone.
If not, you can try to use tile mode, and add some metabuffer (see
mapserver doc <http://mapserver.org/output/tile_mode.html>)
Cheers!
A. Foletti
2016-02-05 10:58 GMT+01:00 Patrick Meis <Meis at stadt-muenster.de>:
> Hallo,
> i have stumbled on a problem.
> I am simulating a buffering of point-data with the help of symbols, which
> I have set to
> sizeunit = meters
> size = 760
> These rather big symbols disappear from my map when I zoom in and
> the center point of the symbol is no longer inside the map window.
> But a significant part of the symbol should still be displayed.
> Is there any possibility of extending the rendered map, so that the
> symbols of my points
> are still rendered even when they are outside my map window?
> Greetz
> Patrick
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160211/70244be2/attachment.html>
