[mapserver-users] RE Inconsistance between display and data
jeansomers
jean.somers at gmail.com
Tue Feb 16 05:38:47 PST 2016
I'm actually beyond projection, I don't even know which data this railway
refers to!!!!!
On Tue, 16 Feb 2016 at 14:36 Steve.Toutant [via OSGeo.org] <
ml-node+s1560n5250815h9 at n6.nabble.com> wrote:
> Maybe bad layer projection parameters ...
> This railway might no be in the projection you think it is....
> *jeansomers <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5250815&i=0>>@lists.osgeo.org
> <http://lists.osgeo.org>*
> Envoyé par : "mapserver-users" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5250815&i=1>>
> 2016-02-16 08:15
> A
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5250815&i=2>
> cc
> Objet
> [mapserver-users] Inconsistance between display and data
> Hi,
> I'm one of two base map administrators for a MapServer web-based
> application.
> We're regularly integrating new base map data, from reception through
> quality check to real integration.
> A while ago, I noticed a base map inconsistance: the map displayed a
> railway
> following the coast in a small peninsula.
> I can tell there is no railway there, I already went to the place. That's
> the beginning.
> So I asked for a correction from the regional administrator, which
> delivered
> me a new version of the local data.
> I checked a last time and discovered that the railway was still on the
> MapServer application.
> I loaded the original data in QGIS, applied the usual symbology : no
> railway.
> I checked the attributes: no railway values in the symbology field.
> My colleague suggested it came from an overlapping data: we checked the
> tile
> indexes of neighbouring data; none was overlapping on the railway tracks.
> There we are, without a clue about the origin of this inconsistance.
> I forgot to mention that we repeatedly deleted application and client
> caches
> inbetween.
> So if you have any idea where it can com from, your suggestions are
> welcomed.
> For your notice, here is the print screen of the issue
> <http://osgeo-org.1560.x6.nabble.com/file/n5250812/33236_0001.png>
> http://osgeo-org.1560.x6.nabble.com/Inconsistance-between-display-and-data-tp5250812.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5250815&i=3>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5250815&i=4>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Inconsistance-between-display-and-data-tp5250812p5250815.html
> To unsubscribe from Inconsistance between display and data, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5250812&code=amVhbi5zb21lcnNAZ21haWwuY29tfDUyNTA4MTJ8MTU2Mjc2NjY3Mg==>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
*SOMERS Jean*
jean.somers at gmailcom
+33 6 26 34 59 96
*Skype:* jeansomers
*LinkedIn:* https://fr.linkedin.com/pub/*jean*-*somers*/4b/9b2/42b
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-RE-Inconsistance-between-display-and-data-tp5250817.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160216/4579dbd8/attachment-0001.html>
