[mapserver-users] RE Inconsistance between display and data
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 16 07:25:11 PST 2016
Perhaps the data is mis-classified? How is the symbol assigned to the data?
Best Regards,
Brent Fraser
On 2/16/2016 6:38 AM, jeansomers wrote:
> I'm actually beyond projection, I don't even know which data this
> railway refers to!!!!!
> On Tue, 16 Feb 2016 at 14:36 Steve.Toutant [via OSGeo.org] <[hidden
> email] </user/SendEmail.jtp?type=node&node=5250817&i=0>> wrote:
> Maybe bad layer projection parameters ...
> This railway might no be in the projection you think it is....
> *jeansomers <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5250815&i=0>>@lists.osgeo.org
> <http://lists.osgeo.org>*
> Envoyé par : "mapserver-users" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5250815&i=1>>
> 2016-02-16 08:15
> A
> [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5250815&i=2>
> cc
> Objet
> [mapserver-users] Inconsistance between display and data
> Hi,
> I'm one of two base map administrators for a MapServer web-based
> application.
> We're regularly integrating new base map data, from reception through
> quality check to real integration.
> A while ago, I noticed a base map inconsistance: the map displayed
> a railway
> following the coast in a small peninsula.
> I can tell there is no railway there, I already went to the place.
> That's
> the beginning.
> So I asked for a correction from the regional administrator, which
> delivered
> me a new version of the local data.
> I checked a last time and discovered that the railway was still on the
> MapServer application.
> I loaded the original data in QGIS, applied the usual symbology : no
> railway.
> I checked the attributes: no railway values in the symbology field.
> My colleague suggested it came from an overlapping data: we
> checked the tile
> indexes of neighbouring data; none was overlapping on the railway
> tracks.
> There we are, without a clue about the origin of this inconsistance.
> I forgot to mention that we repeatedly deleted application and
> client caches
> inbetween.
> So if you have any idea where it can com from, your suggestions are
> welcomed.
> For your notice, here is the print screen of the issue
> <http://osgeo-org.1560.x6.nabble.com/file/n5250812/33236_0001.png>
> http://osgeo-org.1560.x6.nabble.com/Inconsistance-between-display-and-data-tp5250812.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5250815&i=3>
> [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5250815&i=4>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Inconsistance-between-display-and-data-tp5250812p5250815.html
> To unsubscribe from Inconsistance between display and data, click
> here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> *SOMERS Jean*
> jean.somers at gmailcom
> +33 6 26 34 59 96
> _Skype:_ jeansomers
> _LinkedIn:_ https://fr.linkedin.com/pub/*jean*-*somers*/4b/9b2/42b
> View this message in context: Re: RE Inconsistance between display and
> data
> <http://osgeo-org.1560.x6.nabble.com/Re-RE-Inconsistance-between-display-and-data-tp5250817.html>
> <http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html> at
> Nabble.com.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160216/5674272f/attachment.html>
