[mapserver-users] mapscript version and date
Richard Greenwood
richard.greenwood at gmail.com
Tue Feb 23 07:48:02 PST 2016
Well you need to rename map.phtml to map.php. I think that your problem is
that the ".phtml" is not registered with your php handler. So if you don't
want to rename map.phtml you need to modify your Apache config.
On Tue, Feb 23, 2016 at 8:32 AM, Eugenio Trumpy <frippe12573 at hotmail.com>
wrote:
> Hi,
> following your suggestion I tried:
> <http://my_server_name/wm_goth/map.phtml?winsize=large&language=it&config=>
> http://my_server_name/wm_goth/map.php?winsize=large&language=it&config=
> I got page error: NOT FOUND
> The request url /wm_goth/map.php was not found on this server.
> It does help?
> E.
> Date: Tue, 23 Feb 2016 08:27:18 -0700
> Subject: Re: [mapserver-users] mapscript version and date
> From: richard.greenwood at gmail.com
> To: frippe12573 at hotmail.com
> CC: mapserver-users at lists.osgeo.org
> What happens if you change the extension from phtml to php, e.g. map.php
> On Tue, Feb 23, 2016 at 7:43 AM, Eugenio Trumpy <frippe12573 at hotmail.com>
> wrote:
> Hi,
> my info.php states that I have installed Mapserver, version 6.4.1 but no
> date and version are declared
> for php_mapscript.
> On this ubuntu server I recently switched the php mode in apache, from
> normal mod-php5 to mod-fpm.
> Apache rightly interprets the php pages, whilst mapserver (and pmapper)
> have problems.
> The mapserver seems to work fine, the URL
> http://my_server_name/cgi-bin/mapserv?
> gives me the classical string:
> No query information to decode. QUERY_STRING is set, but empty.
> However launching the pmapper application by url:
> I got an almost empty page (only line on the top) and php code in the
> browser tab title.
> Can you give me hints?
> Eugenio
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160223/a5424656/attachment.html>
