[mapserver-users] mapscript version and date
Eugenio Trumpy
frippe12573 at hotmail.com
Tue Feb 23 09:17:08 PST 2016
find a clear guide on how to set AddHandler ... is my problem, I found many guides but
anyone clear.
In my apache2.conf there are no lines on AddHandler, I wonder if I have to insert it on my default virtualhost or wherever.
Any other helps?
Thanks for now
E.
Date: Tue, 23 Feb 2016 09:35:12 -0700
Subject: Re: [mapserver-users] mapscript version and date
To: frippe12573 at hotmail.com
CC: mapserver-users at lists.osgeo.org
You need to add something like this to you apache2.conf or in an .htaccess file
AddHandler application/x-httpd-php .php .phtml
But you might Google a little and find the Ubuntu way of doing it. The .phtml extension got un-registered when you switched to php-fpm.
Rich
On Tue, Feb 23, 2016 at 8:56 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
you are completely right. I just renamed map.phtml in map.php and the application seems to run fine.
Actually I would prefer to register .phtml in my php handler in apache, but since I changed the php module (php-fpm)
I don't know where I should insert the handler.
E.
Date: Tue, 23 Feb 2016 08:48:02 -0700
Well you need to rename map.phtml to map.php. I think that your problem is that the ".phtml" is not registered with your php handler. So if you don't want to rename map.phtml you need to modify your Apache config.
On Tue, Feb 23, 2016 at 8:32 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
following your suggestion I tried:
http://my_server_name/wm_goth/map.php?winsize=large&language=it&config=
I got page error: NOT FOUND
The request url /wm_goth/map.php was not found on this server.
It does help?
E.
Date: Tue, 23 Feb 2016 08:27:18 -0700
What happens if you change the extension from phtml to php, e.g. map.php
On Tue, Feb 23, 2016 at 7:43 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
my info.php states that I have installed Mapserver, version 6.4.1 but no date and version are declared
for php_mapscript.
On this ubuntu server I recently switched the php mode in apache, from normal mod-php5 to mod-fpm.
Apache rightly interprets the php pages, whilst mapserver (and pmapper) have problems.
The mapserver seems to work fine, the URL http://my_server_name/cgi-bin/mapserv?
gives me the classical string:
No query information to decode. QUERY_STRING is set, but empty.
However launching the pmapper application by url:
http://my_server_name/wm_goth/map.phtml?winsize=large&language=it&config=
I got an almost empty page (only line on the top) and php code in the browser tab title.
Can you give me hints?
Eugenio
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160223/cff8caa0/attachment-0001.html>
