[mapserver-users] WMS GetFeatureInfo no processed template on cluster layer
Carlos Ruiz
boolean10001 at yahoo.com
Thu Jan 14 19:51:48 PST 2016
Benjamin,
I have read your post and it seems a different problem, I got no segmentation fault when I perform a WMS GetFeatureInfo request (#5205). What I did to get the field value substitution within the template (PROCESSING "ITEMS=street_name") looks like a workaround.
When a GetFeatureInfo request is made on a cluster symbol, MapServer should return the features information that it groups.
Regards,Carlos Ruiz
#yiv9458951942 #yiv9458951942 -- _filtered #yiv9458951942 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;} _filtered #yiv9458951942 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv9458951942 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv9458951942 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}#yiv9458951942 #yiv9458951942 p.yiv9458951942MsoNormal, #yiv9458951942 li.yiv9458951942MsoNormal, #yiv9458951942 div.yiv9458951942MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:12.0pt;}#yiv9458951942 a:link, #yiv9458951942 span.yiv9458951942MsoHyperlink {color:blue;text-decoration:underline;}#yiv9458951942 a:visited, #yiv9458951942 span.yiv9458951942MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv9458951942 p.yiv9458951942MsoAcetate, #yiv9458951942 li.yiv9458951942MsoAcetate, #yiv9458951942 div.yiv9458951942MsoAcetate {margin:0cm;margin-bottom:.0001pt;font-size:8.0pt;}#yiv9458951942 span.yiv9458951942E-MailFormatvorlage17 {color:#1F497D;}#yiv9458951942 span.yiv9458951942SprechblasentextZchn {}#yiv9458951942 .yiv9458951942MsoChpDefault {font-size:10.0pt;} _filtered #yiv9458951942 {margin:70.85pt 70.85pt 2.0cm 70.85pt;}#yiv9458951942 div.yiv9458951942Section1 {}#yiv9458951942 I can’t confirm your solution, but maybe we’ve got different problems… See my post a week ago:https://github.com/mapserver/mapserver/issues/5219 Maybe someone gets an idea, whether this is an configuration error? Regards Ben Mit freundlichen Grüßen
Im Auftrag
Benjamin Schepers
Luftbild und Geoinformationssysteme
Kronprinzenstraße 35
45128 Essen
Fon: +49 201 2069-232
Fax: +49 201 2069-400
schepers at rvr-online.de
Die Regionaldirektorin
45128 Essen
Zentrale: +49 (0) 201 2069-0
Fax: +49 (0) 201 2069-500
www.metropoleruhr.de
Postfach 10 32 64
45032 Essen
Steuernummer: RVR 112/5797/0116
USt.-ldNr.: DE 173867500
Diese E-Mail koennte vertrauliche und/oder rechtlich geschuetzte Informationen enthalten.
Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail.
Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail sind nicht gestattet.
This e-mail may contain confidential and/or privileged information.
If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail.
Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden. Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]Im Auftrag von Carlos Ruiz
Gesendet: Mittwoch, 13. Januar 2016 20:48
An: MapserverList OSGEO
Betreff: [mapserver-users] WMS GetFeatureInfo no processed template on cluster layer Hi to all,
Maybe I'm missing something, but I cannot retreieve features' information when I have a CLUSTER tag within a WMS layer.
I could retrieve features' information before as text/html on an HTML template performing a GetFeatureInfo query, but after I have included CLUSTER for presentation purposes, the fields on the template are not substituted anymore. The field names are shown as they were written (i.e. [street_name]) on the template.
This can be a little bit obvious because CLUSTER can represent a lot of near features. However, I have tested to retrieve info over a cluster with just one feature and the result is the same.
Is there something that I'm missing or the query behavior on a cluster is just undefined ?
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160115/694a1a0a/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160115/694a1a0a/attachment-0001.jpg>
