[mapserver-users] Rendering VMAP1 & VMAP2 in VPF Format
Michael Smith
michael.smith.erdc at gmail.com
Fri Jan 29 12:32:01 PST 2016
You don't have to convert it (although it may bring you performance to do
so). If your GDAL contains the OGDI driver, you can read it natively
(http://www.gdal.org/drv_ogdi.html)
Mike
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org> on behalf
of "Francis, Mike" <mfrancis at srcinc.com>
Date: Friday, January 29, 2016 at 8:55 AM
To: "'mapserver-users at lists.osgeo.org'" <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Rendering VMAP1 & VMAP2 in VPF Format
> Good Morning,
> What is the easiest way to load Vector Maps (VMAP1 & VMAP2) into map server.
> From what I have read vector maps need to be converted into a shape file and
> then a layer needs to be defined for that shape file. I have created a script
> that takes set of VPF files and creates a point, line, area, and text shape
> file. From that point I am able to create a layer that is able to render
> lines and points. I have not been able to get areas and text vector data to
> display anything. Does a layer require a special property to render area and
> text? Is there an easier way to render VPF data?
> Thanks,
> Mike Francis
> _______________________________________________ mapserver-users mailing list
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160129/f4cbfc78/attachment.html>
