[mapserver-users] kml superoverlays
Páll Péter Hunor
pphunor at itineris.hu
Fri Jan 29 10:05:50 PST 2016
I've debugged the kml driver, and I've managed to solve my problem
making some minor changes in kmlsuperoverlaydataset.cpp.
See the ticket, and the attached source code:
https://trac.osgeo.org/gdal/ticket/6343
Use it up if you think so.
Regards,
Hunor
On 2016.01.27. 19:10, Even Rouault wrote:
> Hunor,
>> I cannot open any data set where the depth of nested levels is greater
>> than 1.
>> Is this limitation by design, or the code is under development?
> I don't recall the details to say if it is by design or just because it was
> not needed at time this was developed, but it is non trivial to turn a .kml
> into a valid GDAL dataset. So the code currently only probably works with some
> formulations of KML, like the one at
> http://mw1.google.com/mw-earth-vectordb/kml-samples/mv-doqq.kml
> A first step would be to file a ticket in GDAL Trac with the KML file that shows
> the issue.
>> If so,
>> when it will be available the support of deeply nested kml superoverlays?
> I'm not aware of anyone actively working on the driver currently. So as often
> in open source, the key to make things go forward is either to contribute
> patches or fund someone to do the work.
> Best regards,
> Even
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
