[mapserver-users] Map file, Label WRAP Function in mapbook removes character it
    Rahkonen Jukka (MML)
    jukka.rahkonen at maanmittauslaitos.fi
    Fri Jul  1 07:31:39 PDT 2016
I just wonder if the aim was to put every part of the list to their own lines
111.
222.
333.
44.
555
If it was, then the "add wrap character with SQL" is fine. If the aim was to keep the label on as few lines as possible  and space admitting have
111.222.333.44.555 or
111.222.333.
44.555
then I fear that no workaround is usable and the real solution would be to change the code to support option "don't eat wrap characters"
-Jukka Rahkonen-
Jeff McKenna wrote:
Great work Benjamin!  (I was looking at that page but didn't think of using substring)  Benjamin's solution works great (assuming your data is always in 111.222.333.44.555  Here is a working example:
  map output: http://pasteboard.co/25N6NcOV.png
  layer snippet:
LAYER
   NAME "test"
   TYPE POINT
   STATUS ON
   CONNECTIONTYPE OGR
   CONNECTION "cities.shp"
   DATA "SELECT
CONCAT(SUBSTR(PARCEL,1,3),'.+',SUBSTR(PARCEL,5,3),'.+',SUBSTR(PARCEL,9,3),'.+',SUBSTR(PARCEL,13,2),'.+',SUBSTR(PARCEL,16,4))
AS parcel_wrap from cities"
   LabelItem "parcel_wrap"
   CLASS
     NAME "mycities"
     LABEL
      COLOR  0 0 0
      FONT sans
      TYPE truetype
      SIZE 8
      POSITION AUTO
      PARTIALS FALSE
      OUTLINECOLOR 255 255 255
      WRAP "+"
     END
     STYLE
       SYMBOL 7
       SIZE 6
       COLOR 0 0 0
     END
   END
END # Layer
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
On 2016-07-01 4:14 AM, Schepers, Benjamin wrote:
> Hi Carrie,
> in my opinion the easiest way would be converting the data to
> spatialite-DB (you get a lot of database-functions in a file based-DB
> - no client-server-architecture, just a file; at best you use ogr2ogr
> or QGIS for conversion) and then use replace function in your
> SQL-QUERY
> i.e. to dynamically insert pipe "|" as wrap-character it should look like that (fieldname is "parcel_no"):
> SELECT *, replace(parcel_no, '.', '.|') AS parcel_no_wrap FROM
> parcel_table
> If you have a shapefile and your parcel-no have a strict pattern (ie. 2digits.3digits.4digits) then it should also be possible to use OGR generic "concat" and "substring"-function, which were introduced with GDAL 1.8 (according to documentation at http://www.gdal.org/ogr_sql.html#ogr_sql_flist_ops and http://www.gdal.org/ogr_sql.html#ogr_sql_functions):
> Example, also with pipe as wrap-character:
> SELECT *,
> CONCAT(SUBSTR(parcel_no,1,2),'.|',SUBSTR(parcel_no,4,3),'.|',SUBSTR(pa
> rcel_no,8,4)) AS parcel_no_wrap FROM parcel_table
> In both examples the new virtual field "parcel_no_wrap" could be used for displaying text with wrap character...
> Sincerely,
> Benjamin Schepers
> Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
> Im Auftrag von Mark Volz
> Gesendet: Donnerstag, 30. Juni 2016 15:09
> An: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Map file, Label WRAP Function in
> Carrie,
> Our trick is to wrap on a character that you would otherwise not normally see in the string.
> LAYER
> 	CLASS
> 		TEXT ([LastName] * [PIN])  #overrides LABELITEM
> 		LABEL
> 			WRAP "*"
> 		END #Parcel Label
> 	END #Parcel Class
> END #Parcel Layer
> Sincerely,
> Mark Volz, GISP
> -----Original Message-----
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
> On Behalf Of mapserver-users-request at lists.osgeo.org
> Sent: Wednesday, June 29, 2016 11:04 AM
> To: mapserver-users at lists.osgeo.org
> Subject: mapserver-users Digest, Vol 101, Issue 37
> Send mapserver-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/mapserver-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	mapserver-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific than "Re: Contents of mapserver-users digest..."
> Today's Topics:
>    1. Map file, Label WRAP Function in mapbook removes character it
>       is wrapping on. (Carrie Quast)
> Message: 1
> Date: Wed, 29 Jun 2016 15:58:59 +0000
> From: Carrie Quast <Carrie.Quast at co.brown.mn.us>
> To: "'mapserver-users at lists.osgeo.org'"
> 	<mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] Map file, Label WRAP Function in mapbook
> 	removes character it is wrapping on.
> Message-ID: <77b9eefcc9264bddb77bd9a85bd037e1 at MSEXCHANGE1.bc.local>
> Content-Type: text/plain; charset="utf-8"
> Hello - I'm working on updating my .MAP Documents to Mapserver 7.0.1.
> I'm trying to get the labels in my Parcel Layer to wrap on the decimal point (example 002.001.001.01.010) to make for a better a fit.  I'm using the WRAP function, which works wonderfully , except it removes the character I am wrapping on.  In this case, the point (.) In my parcel numbers.
> Each of the numbers should have a decimal between it.   Any idea of how to get the line to wrap on a character, but also keep it in the displayed label?  The MAXLENGTH works well too, but still removes all decimal points.
> I'm using Mapserver 7.0.1 with GeoMoose 2.9
> Thank You - Carrie Quast, Brown County MN GIS Specialist
> [cid:image002.png at 01D1D1F5.3D5294F0]
> -------------- next part -------------- An HTML attachment was
> scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160629
> /8bda4b92/attachment.html>
> -------------- next part -------------- A non-text attachment was
> scrubbed...
> Type: image/png
> Desc: image001.png
> URL:
> /8bda4b92/attachment.png>
> scrubbed...
> Type: image/png
> Desc: image002.png
> URL:
> /8bda4b92/attachment-0001.png>
> Subject: Digest Footer
> End of mapserver-users Digest, Vol 101, Issue 37
More information about the MapServer-users
