[mapserver-users] Python MapScript via WSGI examples
Stephan Meißl
stephan at meissl.name
Thu Jul 14 08:57:09 PDT 2016
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Tom,
adding to Julien's response you could also replace
`request.loadParams()` with
`request.loadParamsFromURL(env['QUERY_STRING'])`.
As Julien said, key is that the environment variables are not set
automatically.
cu
Stephan
On 07/14/2016 05:19 PM, Julien-Samuel Lacroix wrote:
> Hi Tom,
> When I run your script, I get the following response:
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> This answer does not contain any content-type that can be stripped wit
h
> msIO_getStdoutBufferBytes(). That's why it returns None.
> Before your OWSRequest call, you need to set the Environment variable
> that MapServer needs. Otherwise they are passed in the env variable an
d
> not to MapServer. Code to add:
> # List of all environment variable used by MapServer
> mapserv_env = [
> 'CONTENT_LENGTH', 'CONTENT_TYPE', 'CURL_CA_BUNDLE', 'HTTP_COOKIE',
> 'HTTP_HOST', 'HTTPS', 'HTTP_X_FORWARDED_HOST', 'HTTP_X_FORWARDED_PORT
> 'HTTP_X_FORWARDED_PROTO', 'MS_DEBUGLEVEL', 'MS_ENCRYPTION_KEY',
> 'MS_ERRORFILE', 'MS_MAPFILE', 'MS_MAPFILE_PATTERN', 'MS_MAP_NO_PATH',
> 'MS_MAP_PATTERN', 'MS_MODE', 'MS_OPENLAYERS_JS_URL', 'MS_TEMPPATH',
> 'MS_XMLMAPFILE_XSLT', 'PROJ_LIB', 'QUERY_STRING', 'REMOTE_ADDR',
> 'REQUEST_METHOD', 'SCRIPT_NAME', 'SERVER_NAME', 'SERVER_PORT'
> for key in mapserv_env:
> if key in env:
> os.environ[key] = env[key]
> else:
> os.unsetenv(key)
> request = mapscript.OWSRequest()
> Best regards,
> Julien
> On 16-07-13 12:55 PM, Kralidis, Tom (EC) wrote:
>> Hi all: we are looking into updating our Python MapScript (CGI-based)
>> wrappers
>> to leverage WSGI, and are having integration issues as part of testin
g.
>> We are using 6.4.2 on Ubuntu 14.04. See example in [1] (against
>> any mapfile is fine). Simple run with python ./mapscript-wsgi.py
>> which makes
>> the server available on localhost:8000 by default.
>> Issues:
>> - the value in
>> https://gist.github.com/tomkralidis/9adbd4864c03647aa7eb4f96a3c33297#
file-mapscript-wsgi-py-L18
>> ends up being a Python None type for some reason when it should be a
>> string of the content-type
>> - issuing a, say, WMS 1.3.0 GetCapabilities request yields the
>> venerable MapServer "This script can ...." default message, when I am
>> expecting Capabilities XML
>> Any ideas what I'm doing wrong here?
>> ..Tom
>> [1] https://gist.github.com/tomkralidis/9adbd4864c03647aa7eb4f96a3c33
297
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=Gj2e
-----END PGP SIGNATURE-----
