[mapserver-users] mapserver-cgi displays nothing
Ahmet Temiz
ahmettemiz88 at gmail.com
Tue Jul 26 06:06:46 PDT 2016
Thank you all,
But the problem still exists.
complete layer portion in the map :
LAYER
NAME 'runtimeSubstitution'
TYPE RASTER
DUMP true
METADATA
"wms_title" "WMS Demo Server"
"wms_onlineresource" "
http://localhost/cgi-bin/mapserv?map=/var/www/trdem1.map&"
"wms_srs" "EPSG:3857"
"WMS_ENABLE_REQUEST" "*"
"wms_feature_info_mime_type" "text/html"
"wms_format" "image/png"
END
PROCESSING "NODATA=0"
PROCESSING "SCALE=AUTO"
PROCESSING "CLOSE_CONNECTION=DEFER"
EXTENT 2857613.741389 4274927.875099 4989786.191152 5176940.449967
DATA 'PG: dbname=tr22 host=localhost user=orkun password=222222
port=5432 schema=public table=o_16_rdem3857 mode=2'
STATUS ON
OPACITY 50
VALIDATION
'yuk' '^[0-9]+$'
END
CLASS
EXPRESSION ([pixel] >= %yuk% )
STYLE COLOR 255 0 0 END
END #end class
END # layer =trdem_4326
http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/trdem1.map&layer=runtimeSubstitution&yuk=500
On Tue, Jul 26, 2016 at 3:35 PM, Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi
> Test systematically. If you test your validation with some service like
> http://www.regexpal.com/ you will find that yuk=50 does not validate
> because it has more than one number in the string.
> Try to validate with ^[0-9]+$
> And yes, variable must be enclosed between %%. That is well documented in
> http://mapserver.org/cgi/runsub.html.
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org>
> käyttäjän puolestaYves Jacolin <yves.jacolin at camptocamp.com>
> Lähetetty: 26. heinäkuuta 2016 10:17
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] mapserver-cgi displays nothing
> On Tuesday, July 26, 2016 10:12:58 Ahmet Temiz wrote:
> > Our mapserver-cgi displays nothing.
> > VALIDATION
> > 'yuk' '^[0-9]$'
> > END
> > CLASS
> > EXPRESSION ([pixel] >= 'yuk' )
> > END #end class
> > What am I doing wrong?
> > regards
> Hello,
> You should probably use %:
> EXPRESSION ([pixel] >= '%yuk%' )
> Y.
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 58 48 20 43 (new !)
> Tel (Suisse) : +41 21 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160726/fab5b4e5/attachment-0001.html>
