[mapserver-users] Building Mapserver - missing strlcat... methods
Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
matthew.f.cechini at nasa.gov
Tue Jun 21 11:41:06 PDT 2016
As it turns out, the issue is Harfbuzz:
In the pre-compile checks, I see this:
-- checking for module 'harfbuzz>=0.9.18'
-- package 'harfbuzz>=0.9.18' not found
-- Found HarfBuzz: /usr/local/include/harfbuzz
Seems ok, it didn’t find an installed RPM/package, but it finds the directory where I build and installed manually.
But the problem then is that there is a missing header file from Harfbuzz:
In file included from /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:32:
/home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.h:15:20: error: hb-ft.h: No such file or directory
/home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c: In function 'msFreeFontCache':
/home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:82: warning: implicit declaration of function 'hb_font_destroy'
/home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:84: warning: implicit declaration of function 'hb_font_funcs_destroy'
I see that particular header file in the src directory, from which `make install` is run for harfbuzz… but it’s not “installed”. I can’t seem to find an RPM for Centos 6, so building from source seems to be the path I have to follow.
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
From: Thomas Gratier <osgeo.mailinglist at gmail.com<mailto:osgeo.mailinglist at gmail.com>>
Date: Tuesday, June 21, 2016 at 12:30 PM
To: Matthew Cechini <matthew.f.cechini at nasa.gov<mailto:matthew.f.cechini at nasa.gov>>
Cc: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: Re: [mapserver-users] Building Mapserver - missing strlcat... methods
"build map server 7.0.1 on linux": distro, architecture?
You should look at https://github.com/mapserver/mapserver/blob/branch-7-0/.travis.yml to find out more about MapServer deps.
Cheers
Thomas Gratier
2016-06-20 22:35 GMT+02:00 Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov<mailto:matthew.f.cechini at nasa.gov>>:
I’m attempting to build map server 7.0.1 on linux and am getting the following errors. I’m sure I’m missing some dependency… but google has failed me to figure it out. Help?
-- Looking for strrstr - not found
-- Looking for strlcat - not found
-- Looking for strlcpy - not found
-- Looking for PQserverVersion in pq - not found
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads - not found
Matt
Matthew Cechini
410.205.6272<tel:410.205.6272>
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160621/f6935ac9/attachment-0001.html>
