[mapserver-users] zipped shapefile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jun 22 15:46:19 PDT 2016
I'm also unable to get this to work. I agree that it should (with the
layer specified in the "DATA" statement), but I can't seem to get
MapServer 7.0.1 to draw a map. The error message is quite generic:
OGROpen(/vsizip/test.zip)
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
'test'. File not found or unsupported format.
I believe you have found a nice enhancement. I think you should file
this in the issue tracker: https://github.com/mapserver/mapserver/issues
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-06-22 5:57 PM, lagrange123 wrote:
> Hi,
> I have a bunch of shapefiles in zip format for disk space reasons. And I
> want to be able to server their contents with mapserver. Is this possible?
> I was thinking that I could use CONNECTIONTYPE OGR. And then, since gdal/ogr
> can read a zipped data source (per
> https://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip), this would enable
> mapserver to serve such a data source. However, I am not having much luck,
> and I don't know if this is even supported in mapserver.
> My layer definition is:
> LAYER
> NAME "my_shapefile"
> CONNECTIONTYPE OGR
> CONNECTION "/vsizip/path/to/file.zip"
> TYPE POLYGON
> STATUS ON
> END
