[mapserver-users] zipped shapefile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jun 23 12:01:47 PDT 2016
I've added these examples into a new document named "Virtual File
System": http://mapserver.org/input/virtual-file.html
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-06-23 9:52 AM, Ben Grange wrote:
> Thanks for the speedy replies, guys. I have it working now. For me the
> issue was the product of (1) using a relative path, and (2) using the
> wrong TYPE. Silly me!
> On Thu, Jun 23, 2016 at 7:34 AM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> On 2016-06-23 3:49 AM, Even Rouault wrote:
> > Definitely not in the DATA that must be a layer name or SQL
> SELECT, but in CONNECTION.
> > It is important to put the absolute path, as the SHAPEPATH
> directive will have no effect on
> > a /vsizip/ filename. As Mike raised, it is recommended to put the
> filename of the shape too.
> > (you may omit it if the .shp is at the root of the .zip and
> there's no other "extra" file than the ones
> > expected for a shapefile. When you omit it, the zip is recognized
> as a directory and it is the
> > same logic as doing ogrinfo on a directory that is applied. Will
> work with directory of shapefiles
> > and .tab/.mif for example)
> Thank you Even, my issue was the full path requirement. I will document
> this now.
> Below is my working layer (with MS4W 3.1.4 / MapServer 7.0.1) :
> LAYER
> NAME "testzip"
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "/vsizip/D:/ms4w/apps/test/test.zip"
> DATA "test"
> CLASS
> NAME "test"
> STYLE
> COLOR 240 240 240
> OUTLINECOLOR 199 199 199
> END
> END
> END # layer
> -jeff
