[mapserver-users] Building Mapserver - missing strlcat... methods
thomas bonfort
thomas.bonfort at gmail.com
Fri Jun 24 02:46:46 PDT 2016
The str* missising functions should not be an issue, those are just
checks to see if we shall be providing our own implementation. Are you
sure you posted the whole cmake log ?
thomas
On 24 June 2016 at 11:31, Michael Schulz <mandschulz at googlemail.com> wrote:
> Hi Thomas,
> nope, unfortunately not. Deleted everything, rerun cmake, still got the same
> errors (strsstr, strlcat, strlcpy not found). This is one part of
> CMakeError.log:
> Determining if the function strrstr exists failed with the following output:
> Change Dir: /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp
> Run Build Command:"/usr/bin/gmake" "cmTryCompileExec1997038117/fast"
> /usr/bin/gmake -f CMakeFiles/cmTryCompileExec1997038117.dir/build.make
> gmake[1]: Entering directory
> `/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp'
> /usr/bin/cmake -E cmake_progress_report
> /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/CMakeFiles 1
> Building C object
> CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o
> /usr/bin/cc -DCHECK_FUNCTION_EXISTS=strrstr
> -I/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/math.h -o
> CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -c
> /usr/share/cmake/Modules/CheckFunctionExists.c
> Linking C executable cmTryCompileExec1997038117
> /usr/bin/cmake -E cmake_link_script
> CMakeFiles/cmTryCompileExec1997038117.dir/link.txt --verbose=1
> CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -o
> cmTryCompileExec1997038117 -rdynamic -lm
> CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o: In
> function `main':
> CheckFunctionExists.c:(.text+0x15): undefined reference to `strrstr'
> collect2: ld gab 1 als Ende-Status zurück
> gmake[1]: Leaving directory
> gmake[1]: *** [cmTryCompileExec1997038117] Fehler 1
> gmake: *** [cmTryCompileExec1997038117/fast] Fehler 2
> ... (this is similarly repeated for the other functions)
> Thanks, Michael
> 2016-06-24 10:09 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> Try deleting everything in the build directory and starting again,
>> might be a cmake cache problem...
>> On 24 June 2016 at 10:07, Michael Schulz <mandschulz at googlemail.com>
>> wrote:
>> > Hi,
>> > I have exactly the same issue here. Trying to build mapserver on SLES 11
>> > SP4, I have disabled harfbuzz and fribidi:
>> > cmake .. \
>> > -DCMAKE_PREFIX_PATH=/opt/gdal-trunk \
>> > -DWITH_CLIENT_WFS=ON \
>> > -DWITH_CLIENT_WMS=ON \
>> > -DWITH_CURL=ON \
>> > -DWITH_SOS=ON \
>> > -DWITH_PHP=ON \
>> > -DWITH_PYTHON=ON \
>> > -DWITH_SVGCAIRO=ON \
>> > -DWITH_ORACLESPATIAL=ON \
>> > -DWITH_HARFBUZZ=0 \
>> > -DWITH_FRIBIDI=0 \
>> > -DWITH_FCGI=0 \
>> > >../configure.out.txt
>> > configure.out:
>> > -- The C compiler identification is GNU 4.3.4
>> > -- The CXX compiler identification is GNU 4.3.4
>> > -- Check for working C compiler: /usr/bin/cc
>> > -- Check for working C compiler: /usr/bin/cc -- works
>> > -- Detecting C compiler ABI info
>> > -- Detecting C compiler ABI info - done
>> > -- Check for working CXX compiler: /usr/bin/c++
>> > -- Check for working CXX compiler: /usr/bin/c++ -- works
>> > -- Detecting CXX compiler ABI info
>> > -- Detecting CXX compiler ABI info - done
>> > -- Looking for strrstr
>> > -- Looking for strrstr - not found
>> > -- Looking for strcasecmp
>> > -- Looking for strcasecmp - found
>> > -- Looking for strcasestr
>> > -- Looking for strcasestr - found
>> > -- Looking for strdup
>> > -- Looking for strdup - found
>> > -- Looking for strlcat
>> > -- Looking for strlcat - not found
>> > -- Looking for strlcpy
>> > -- Looking for strlcpy - not found
>> > -- Looking for strlen
>> > -- Looking for strlen - found
>> > -- Looking for strncasecmp
>> > -- Looking for strncasecmp - found
>> > -- Looking for vsnprintf
>> > -- Looking for vsnprintf - found
>> > -- Looking for lrintf
>> > -- Looking for lrintf - found
>> > -- Looking for lrint - found
>> > -- Looking for dlfcn.h
>> > -- Looking for dlfcn.h - found
>> > -- Performing Test HAVE_SYNC_FETCH_AND_ADD
>> > -- Performing Test HAVE_SYNC_FETCH_AND_ADD - Success
>> > -- Found ZLIB: /usr/lib64/libz.so (found version "1.2.7")
>> > -- Found PNG: /usr/lib64/libpng.so (found version "1.2.31")
>> > -- Found JPEG: /usr/lib64/libjpeg.so
>> > -- Found Freetype: /usr/lib64/libfreetype.so
>> > -- Found PROJ: /usr/lib64/libproj.so
>> > -- Looking for iconv
>> > -- Looking for iconv - found
>> > -- Found iconv library:
>> > -- Found PkgConfig: /usr/bin/pkg-config (found version "0.23")
>> > -- checking for module 'cairo'
>> > -- found cairo, version 1.8.8
>> > -- Found CAIRO: /usr/lib64/libcairo.so
>> > -- Found ORACLE:
>> > /home/oracle/app/oracle/product/12.1.0/client_1/lib/libclntsh.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libocci.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libnnz12.so
>> > -- Found GEOS: /usr/lib64/libgeos_c.so
>> > -- Found POSTGRESQL: /usr/lib64/libpq.so
>> > -- Looking for PQserverVersion in pq
>> > -- Looking for PQserverVersion in pq - found
>> > -- Found GDAL: /opt/gdal-trunk/lib/libgdal.so
>> > -- Found SVG: /usr/local/lib/libsvg.so
>> > -- Found SVGCAIRO: /usr/local/lib/libsvg-cairo.so
>> > -- Found CURL: /usr/lib64/libcurl.so (found version "7.19.7")
>> > -- Found LibXml2: /usr/lib64/libxml2.so (found version "2.7.6")
>> > -- Performing Test GIF_GifFileType_UserData
>> > -- Performing Test GIF_GifFileType_UserData - Success
>> > -- Found GIF: /usr/lib64/libgif.so (found version "4")
>> > -- Found SWIG: /usr/bin/swig (found version "1.3.36")
>> > -- Found PythonInterp: /usr/bin/python (found version "2.6.9")
>> > -- * Summary of configured options for this build
>> > -- * Mandatory components
>> > -- * png: /usr/lib64/libpng.so
>> > -- * jpeg: /usr/lib64/libjpeg.so
>> > -- * freetype: /usr/lib64/libfreetype.so
>> > -- * Optional components
>> > -- * GDAL: /opt/gdal-trunk/lib/libgdal.so
>> > -- * OGR: /opt/gdal-trunk/lib/libgdal.so
>> > -- * GIF: /usr/lib64/libgif.so
>> > -- * MYSQL: disabled
>> > -- * FRIBIDI: disabled
>> > -- * HARFBUZZ: disabled
>> > -- * CAIRO: /usr/lib64/libcairo.so
>> > -- * SVGCAIRO: /usr/local/lib/libsvg-cairo.so
>> > -- * RSVG: disabled
>> > -- * CURL: /usr/lib64/libcurl.so
>> > -- * PROJ: /usr/lib64/libproj.so
>> > -- * PIXMAN: disabled
>> > -- * LIBXML2: /usr/lib64/libxml2.so
>> > -- * POSTGIS: /usr/lib64/libpq.so
>> > -- * GEOS: /usr/lib64/libgeos_c.so
>> > -- * FastCGI: disabled
>> > -- * Oracle Spatial:
>> > -- * Exempi XMP: disabled
>> > -- * Optional features
>> > -- * WMS SERVER: ENABLED
>> > -- * WFS SERVER: ENABLED
>> > -- * WCS SERVER: ENABLED
>> > -- * SOS SERVER: ENABLED
>> > -- * WMS CLIENT: ENABLED
>> > -- * WFS CLIENT: ENABLED
>> > -- * ICONV: ENABLED
>> > -- * Thread-safety support: disabled
>> > -- * KML output: disabled
>> > -- * Z+M point coordinate support: disabled
>> > -- * XML Mapfile support: disabled
>> > -- * Mapscripts
>> > -- * Python: ENABLED
>> > -- * PHP: ENABLED
>> > -- * PERL: disabled
>> > -- * RUBY: disabled
>> > -- * JAVA: disabled
>> > -- * C#: disabled
>> > -- * V8 Javascript: disabled
>> > -- * Apache Module (Experimental): disabled
>> > -- Will install files to /usr/local
>> > -- Will install libraries to /usr/local/lib
>> > -- Configuring incomplete, errors occurred!
>> > Is this related to disabling Harfbuzz or Fribidi? I understood that
>> > Harfbuzz
>> > is not needed unless for special languages character rendering?
>> > Thanks, Michael
>> > 2016-06-24 8:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> >> Matthew,
>> >> What configure flags did you use to build harfbuzz? What harfbuzz
>> >> version are you using?
>> >> thomas
>> >> On 21 June 2016 at 20:41, Cechini, Matthew F. (GSFC-423.0)[Science
>> >> Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov> wrote:
>> >> > As it turns out, the issue is Harfbuzz:
>> >> > In the pre-compile checks, I see this:
>> >> > -- checking for module 'harfbuzz>=0.9.18'
>> >> > -- package 'harfbuzz>=0.9.18' not found
>> >> > -- Found HarfBuzz: /usr/local/include/harfbuzz
>> >> > Seems ok, it didn’t find an installed RPM/package, but it finds the
>> >> > directory where I build and installed manually.
>> >> > But the problem then is that there is a missing header file from
>> >> > Harfbuzz:
>> >> > In file included from
>> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:32:
>> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.h:15:20:
>> >> > error:
>> >> > hb-ft.h: No such file or directory
>> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c: In function
>> >> > 'msFreeFontCache':
>> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:82: warning:
>> >> > implicit declaration of function 'hb_font_destroy'
>> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:84: warning:
>> >> > implicit declaration of function 'hb_font_funcs_destroy'
>> >> > I see that particular header file in the src directory, from which
>> >> > `make
>> >> > install` is run for harfbuzz… but it’s not “installed”. I can’t seem
>> >> > to
>> >> > find an RPM for Centos 6, so building from source seems to be the
>> >> > path I
>> >> > have to follow.
>> >> > Matt
>> >> > Matthew Cechini
>> >> > Contractor, Science Systems and Applications, Inc.
>> >> > NASA GIBS Systems/Software Engineer
>> >> > 410.205.6272
>> >> > From: Thomas Gratier <osgeo.mailinglist at gmail.com>
>> >> > Date: Tuesday, June 21, 2016 at 12:30 PM
>> >> > To: Matthew Cechini <matthew.f.cechini at nasa.gov>
>> >> > Cc: "mapserver-users at lists.osgeo.org"
>> >> > <mapserver-users at lists.osgeo.org>
>> >> > Subject: Re: [mapserver-users] Building Mapserver - missing
>> >> > strlcat...
>> >> > methods
>> >> > Hi,
>> >> > "build map server 7.0.1 on linux": distro, architecture?
>> >> > You should look at
>> >> > https://github.com/mapserver/mapserver/blob/branch-7-0/.travis.yml to
>> >> > find
>> >> > out more about MapServer deps.
>> >> > Cheers
>> >> > Thomas Gratier
>> >> > 2016-06-20 22:35 GMT+02:00 Cechini, Matthew F. (GSFC-423.0)[Science
>> >> > Systems
>> >> > & Applications, Inc.] <matthew.f.cechini at nasa.gov>:
>> >> >> I’m attempting to build map server 7.0.1 on linux and am getting the
>> >> >> following errors. I’m sure I’m missing some dependency… but google
>> >> >> has
>> >> >> failed me to figure it out. Help?
>> >> >> -- Looking for PQserverVersion in pq - not found
>> >> >> -- Looking for pthread_create - not found
>> >> >> -- Looking for pthread_create in pthreads - not found
>> >> >> Matt
>> >> >> Matthew Cechini
>> >> >> 410.205.6272
>> >> >> _______________________________________________
>> >> >> mapserver-users mailing list
>> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> > Michael Schulz
