[mapserver-users] Building Mapserver - missing strlcat... methods
thomas bonfort
thomas.bonfort at gmail.com
Fri Jun 24 04:53:38 PDT 2016
Your error is somehow coming from the php installation/configuration.
Check your log messages for something there.
On 24 June 2016 at 13:49, Michael Schulz <mandschulz at googlemail.com> wrote:
> Hi Thomas,
> I'm pretty sure it is. Just did a rm -rf * on the build dir, and then this:
> :/usr/local/src/mapserver-7.0.1/build # cmake ..
> -DCMAKE_INSTALL_PREFIX=/opt/mapserver-7.0.1
> -DCMAKE_PREFIX_PATH=/opt/gdal-trunk -DWITH_CLIENT_WFS=ON
> -DWITH_CLIENT_WMS=ON -DWITH_CURL=ON -DWITH_SOS=ON
> -DWITH_PHP=ON -DWITH_PYTHON=ON -DWITH_SVGCAIRO=ON
> -DWITH_ORACLESPATIAL=ON -DWITH_HARFBUZZ=0 -DWITH_FRIBIDI=0
> -DWITH_FCGI=0
> -- The C compiler identification is GNU 4.3.4
> -- The CXX compiler identification is GNU 4.3.4
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Looking for strrstr
> -- Looking for strrstr - not found
> -- Looking for strcasecmp
> -- Looking for strcasecmp - found
> -- Looking for strcasestr
> -- Looking for strcasestr - found
> -- Looking for strdup
> -- Looking for strdup - found
> -- Looking for strlcat
> -- Looking for strlcat - not found
> -- Looking for strlcpy
> -- Looking for strlcpy - not found
> -- Looking for strlen
> -- Looking for strlen - found
> -- Looking for strncasecmp
> -- Looking for strncasecmp - found
> -- Looking for vsnprintf
> -- Looking for vsnprintf - found
> -- Looking for lrintf
> -- Looking for lrintf - found
> -- Looking for lrint - found
> -- Looking for dlfcn.h
> -- Looking for dlfcn.h - found
> -- Performing Test HAVE_SYNC_FETCH_AND_ADD
> -- Performing Test HAVE_SYNC_FETCH_AND_ADD - Success
> -- Found ZLIB: /usr/lib64/libz.so (found version "1.2.7")
> -- Found PNG: /usr/lib64/libpng.so (found version "1.2.31")
> -- Found JPEG: /usr/lib64/libjpeg.so
> -- Found Freetype: /usr/lib64/libfreetype.so
> -- Found PROJ: /usr/lib64/libproj.so
> -- Looking for iconv
> -- Looking for iconv - found
> -- Found iconv library:
> -- Found PkgConfig: /usr/bin/pkg-config (found version "0.23")
> -- checking for module 'cairo'
> -- found cairo, version 1.8.8
> -- Found CAIRO: /usr/lib64/libcairo.so
> ORACLE_HOME=/home/oracle/app/oracle/product/12.1.0/client_1
> -- Found ORACLE:
> /home/oracle/app/oracle/product/12.1.0/client_1/lib/libclntsh.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libocci.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libnnz12.so
> -- Found GEOS: /usr/lib64/libgeos_c.so
> -- Found POSTGRESQL: /usr/lib64/libpq.so
> -- Looking for PQserverVersion in pq
> -- Looking for PQserverVersion in pq - found
> -- Found GDAL: /opt/gdal-trunk/lib/libgdal.so
> -- Found SVG: /usr/local/lib/libsvg.so
> -- Found SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> -- Found CURL: /usr/lib64/libcurl.so (found version "7.19.7")
> -- Found LibXml2: /usr/lib64/libxml2.so (found version "2.7.6")
> -- Performing Test GIF_GifFileType_UserData
> -- Performing Test GIF_GifFileType_UserData - Success
> -- Found GIF: /usr/lib64/libgif.so (found version "4")
> -- Found SWIG: /usr/bin/swig (found version "1.3.36")
> -- Found PythonInterp: /usr/bin/python (found version "2.6.9")
> CMake Warning (dev) at mapscript/python/CMakeLists.txt:42
> (get_target_property):
> Policy CMP0026 is not set: Disallow use of the LOCATION target property.
> Run "cmake --help-policy CMP0026" for policy details. Use the
> cmake_policy
> command to set the policy and suppress this warning.
> The LOCATION property should not be read from target "_pythonmapscript".
> Use the target name directly with add_custom_command, or use the generator
> expression $<TARGET_FILE>, as appropriate.
> This warning is for project developers. Use -Wno-dev to suppress it.
> CMake Error at mapscript/php/CMakeLists.txt:31 (install):
> install TARGETS given no LIBRARY DESTINATION for module target
> "php_mapscript".
> -- * Summary of configured options for this build
> -- * Mandatory components
> -- * png: /usr/lib64/libpng.so
> -- * jpeg: /usr/lib64/libjpeg.so
> -- * freetype: /usr/lib64/libfreetype.so
> -- * Optional components
> -- * GDAL: /opt/gdal-trunk/lib/libgdal.so
> -- * OGR: /opt/gdal-trunk/lib/libgdal.so
> -- * GIF: /usr/lib64/libgif.so
> -- * MYSQL: disabled
> -- * FRIBIDI: disabled
> -- * HARFBUZZ: disabled
> -- * CAIRO: /usr/lib64/libcairo.so
> -- * SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> -- * RSVG: disabled
> -- * CURL: /usr/lib64/libcurl.so
> -- * PROJ: /usr/lib64/libproj.so
> -- * PIXMAN: disabled
> -- * LIBXML2: /usr/lib64/libxml2.so
> -- * POSTGIS: /usr/lib64/libpq.so
> -- * GEOS: /usr/lib64/libgeos_c.so
> -- * FastCGI: disabled
> -- * Oracle Spatial:
> -- * Exempi XMP: disabled
> -- * Optional features
> -- * WMS SERVER: ENABLED
> -- * WFS SERVER: ENABLED
> -- * WCS SERVER: ENABLED
> -- * SOS SERVER: ENABLED
> -- * WMS CLIENT: ENABLED
> -- * WFS CLIENT: ENABLED
> -- * ICONV: ENABLED
> -- * Thread-safety support: disabled
> -- * KML output: disabled
> -- * Z+M point coordinate support: disabled
> -- * XML Mapfile support: disabled
> -- * Mapscripts
> -- * Python: ENABLED
> -- * PHP: ENABLED
> -- * PERL: disabled
> -- * RUBY: disabled
> -- * JAVA: disabled
> -- * C#: disabled
> -- * V8 Javascript: disabled
> -- * Apache Module (Experimental): disabled
> -- Will install files to /opt/mapserver-7.0.1
> -- Will install libraries to /opt/mapserver-7.0.1/lib
> -- Configuring incomplete, errors occurred!
> See also "/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeOutput.log".
> See also "/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeError.log".
> Thanks, Michael
> 2016-06-24 11:46 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> The str* missising functions should not be an issue, those are just
>> checks to see if we shall be providing our own implementation. Are you
>> sure you posted the whole cmake log ?
>> thomas
>> On 24 June 2016 at 11:31, Michael Schulz <mandschulz at googlemail.com>
>> wrote:
>> > Hi Thomas,
>> > nope, unfortunately not. Deleted everything, rerun cmake, still got the
>> > same
>> > errors (strsstr, strlcat, strlcpy not found). This is one part of
>> > CMakeError.log:
>> > Determining if the function strrstr exists failed with the following
>> > output:
>> > Change Dir: /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp
>> > Run Build Command:"/usr/bin/gmake" "cmTryCompileExec1997038117/fast"
>> > /usr/bin/gmake -f CMakeFiles/cmTryCompileExec1997038117.dir/build.make
>> > gmake[1]: Entering directory
>> > `/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp'
>> > /usr/bin/cmake -E cmake_progress_report
>> > /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/CMakeFiles 1
>> > Building C object
>> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o
>> > /usr/bin/cc -DCHECK_FUNCTION_EXISTS=strrstr
>> > -I/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/math.h -o
>> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -c
>> > /usr/share/cmake/Modules/CheckFunctionExists.c
>> > Linking C executable cmTryCompileExec1997038117
>> > /usr/bin/cmake -E cmake_link_script
>> > CMakeFiles/cmTryCompileExec1997038117.dir/link.txt --verbose=1
>> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -o
>> > cmTryCompileExec1997038117 -rdynamic -lm
>> > CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o: In
>> > function `main':
>> > CheckFunctionExists.c:(.text+0x15): undefined reference to `strrstr'
>> > collect2: ld gab 1 als Ende-Status zurück
>> > gmake[1]: Leaving directory
>> > gmake[1]: *** [cmTryCompileExec1997038117] Fehler 1
>> > gmake: *** [cmTryCompileExec1997038117/fast] Fehler 2
>> > ... (this is similarly repeated for the other functions)
>> > Thanks, Michael
>> > 2016-06-24 10:09 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> >> Try deleting everything in the build directory and starting again,
>> >> might be a cmake cache problem...
>> >> On 24 June 2016 at 10:07, Michael Schulz <mandschulz at googlemail.com>
>> >> wrote:
>> >> > Hi,
>> >> > I have exactly the same issue here. Trying to build mapserver on SLES
>> >> > 11
>> >> > SP4, I have disabled harfbuzz and fribidi:
>> >> > cmake .. \
>> >> > -DCMAKE_PREFIX_PATH=/opt/gdal-trunk \
>> >> > -DWITH_CLIENT_WFS=ON \
>> >> > -DWITH_CLIENT_WMS=ON \
>> >> > -DWITH_CURL=ON \
>> >> > -DWITH_SOS=ON \
>> >> > -DWITH_PHP=ON \
>> >> > -DWITH_PYTHON=ON \
>> >> > -DWITH_SVGCAIRO=ON \
>> >> > -DWITH_ORACLESPATIAL=ON \
>> >> > -DWITH_HARFBUZZ=0 \
>> >> > -DWITH_FRIBIDI=0 \
>> >> > -DWITH_FCGI=0 \
>> >> > >../configure.out.txt
>> >> > configure.out:
>> >> > -- Found ORACLE:
>> >> > -- * RSVG: disabled
>> >> > -- * ICONV: ENABLED
>> >> > -- * Mapscripts
>> >> > -- * PHP: ENABLED
>> >> > -- * PERL: disabled
>> >> > -- * RUBY: disabled
>> >> > -- * JAVA: disabled
>> >> > -- * C#: disabled
>> >> > -- Will install files to /usr/local
>> >> > -- Will install libraries to /usr/local/lib
>> >> > Is this related to disabling Harfbuzz or Fribidi? I understood that
>> >> > Harfbuzz
>> >> > is not needed unless for special languages character rendering?
>> >> > Thanks, Michael
>> >> > 2016-06-24 8:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> >> >> Matthew,
>> >> >> What configure flags did you use to build harfbuzz? What harfbuzz
>> >> >> version are you using?
>> >> >> thomas
>> >> >> On 21 June 2016 at 20:41, Cechini, Matthew F. (GSFC-423.0)[Science
>> >> >> Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov> wrote:
>> >> >> > As it turns out, the issue is Harfbuzz:
>> >> >> > In the pre-compile checks, I see this:
>> >> >> > -- checking for module 'harfbuzz>=0.9.18'
>> >> >> > -- package 'harfbuzz>=0.9.18' not found
>> >> >> > -- Found HarfBuzz: /usr/local/include/harfbuzz
>> >> >> > Seems ok, it didn’t find an installed RPM/package, but it finds
>> >> >> > the
>> >> >> > directory where I build and installed manually.
>> >> >> > But the problem then is that there is a missing header file from
>> >> >> > Harfbuzz:
>> >> >> > In file included from
>> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:32:
>> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.h:15:20:
>> >> >> > error:
>> >> >> > hb-ft.h: No such file or directory
>> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c: In
>> >> >> > function
>> >> >> > 'msFreeFontCache':
>> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:82:
>> >> >> > warning:
>> >> >> > implicit declaration of function 'hb_font_destroy'
>> >> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:84:
>> >> >> > warning:
>> >> >> > implicit declaration of function 'hb_font_funcs_destroy'
>> >> >> > I see that particular header file in the src directory, from which
>> >> >> > `make
>> >> >> > install` is run for harfbuzz… but it’s not “installed”. I can’t
>> >> >> > seem
>> >> >> > to
>> >> >> > find an RPM for Centos 6, so building from source seems to be the
>> >> >> > path I
>> >> >> > have to follow.
>> >> >> > Matt
>> >> >> > Matthew Cechini
>> >> >> > Contractor, Science Systems and Applications, Inc.
>> >> >> > NASA GIBS Systems/Software Engineer
>> >> >> > 410.205.6272
>> >> >> > From: Thomas Gratier <osgeo.mailinglist at gmail.com>
>> >> >> > Date: Tuesday, June 21, 2016 at 12:30 PM
>> >> >> > To: Matthew Cechini <matthew.f.cechini at nasa.gov>
>> >> >> > Cc: "mapserver-users at lists.osgeo.org"
>> >> >> > <mapserver-users at lists.osgeo.org>
>> >> >> > Subject: Re: [mapserver-users] Building Mapserver - missing
>> >> >> > strlcat...
>> >> >> > methods
>> >> >> > Hi,
>> >> >> > "build map server 7.0.1 on linux": distro, architecture?
>> >> >> > You should look at
>> >> >> > https://github.com/mapserver/mapserver/blob/branch-7-0/.travis.yml
>> >> >> > to
>> >> >> > find
>> >> >> > out more about MapServer deps.
>> >> >> > Cheers
>> >> >> > Thomas Gratier
>> >> >> > 2016-06-20 22:35 GMT+02:00 Cechini, Matthew F.
>> >> >> > Systems
>> >> >> > & Applications, Inc.] <matthew.f.cechini at nasa.gov>:
>> >> >> >> I’m attempting to build map server 7.0.1 on linux and am getting
>> >> >> >> the
>> >> >> >> following errors. I’m sure I’m missing some dependency… but
>> >> >> >> google
>> >> >> >> has
>> >> >> >> failed me to figure it out. Help?
>> >> >> >> -- Looking for PQserverVersion in pq - not found
>> >> >> >> -- Looking for pthread_create - not found
>> >> >> >> -- Looking for pthread_create in pthreads - not found
>> >> >> >> Matt
>> >> >> >> Matthew Cechini
>> >> >> >> 410.205.6272
>> >> >> >> _______________________________________________
>> >> >> >> mapserver-users mailing list
>> >> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> > Michael Schulz
