[mapserver-users] Mapserver JOIN to html template
Marco Afonso
mafonso333 at gmail.com
Thu Mar 10 12:37:29 PST 2016
If you use views in PostgreSQL to join the tables, you may not need go use
the Join in mapfile.
Em 10/03/2016 18:48, "Pierre-Étienne Lord" <pe_lord at yahoo.ca> escreveu:
> Hi everybody, it's my first question ever on this list.
> <mapserver-users%40lists.osgeo.org>
> Some facts before
> I'm running Mapserver 6.2.1 (old vm machine)
> Postgres 9.3.6 with postgis 2.1.7
> Postgres is listening all IP and accept all incoming IP. pg_hba.conf an
> postgresql.conf
> Publishing succesfully multiple layers base on Postgis and everything seem
> to be ok.
> I try to make a template presenting ONE-TO-MANY content from PG to PG.(
> http://mapserver.org/mapfile/join.html)
> My ONE part is my geometry and is published in WMS
> My MANY is an associated table.
> My key between my 2 tables is a unique string (21) named geocode
> Both have PK.
> Here my problem.
> On getfeatureinfo, it is suppose to return a html mime type for my
> template. Header, central (MANY) and FOOTER.
> When I call the same dataset in DBF, the getfeatureinfo is returned
> properly.
> When I call the same dataset in postgres, the getfeatureinfo is NOT
> returned properly.
> I think that my connection is well done by connection string because if I
> change table or column name to a not existing one, MapServer raise an error.
> This example don't work properly.
> TEMPLATE "oneToMany.html"
> HEADER "oneToMany_header.html"
> FOOTER "oneToMany_footer.html"
> JOIN
> NAME 'ieqm'
> CONNECTIONTYPE postgresql
> CONNECTION "host=XX.XX.XX.XX port=XXXX user=PG password=PGPWD
> dbname=BDX"
> TABLE 'table_150513"
> FROM 'geocode'
> TO 'geocode'
> TYPE ONE-TO-MANY
> TEMPLATE 'oneToMany_join.html'
> END
> This example work properly.
> JOIN
> NAME 'ieqm'
> TABLE "table_150513.dbf"
> FROM 'geocode'
> TO 'geocode'
> TYPE ONE-TO-MANY
> END
> Thanks!
> Pierre-Étienne Lord
> <https://outlook.mrnf.gouv.qc.ca/owa/redir.aspx?SURL=YaZ5UYf2IPMJv7ADsBDnNhbct83j8H_NQZOvg_R1SvvMdStAFEnTCG0AYQBpAGwAdABvADoAcABpAGUAcgByAGUALQBlAHQAaQBlAG4AbgBlAC4AbABvAHIAZABAAG0AZgBmAHAALgBnAG8AdQB2AC4AcQBjAC4AYwBhAA..&URL=mailto%3apierre-etienne.lord%40mffp.gouv.qc.ca>
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160310/a8a3b653/attachment.htm>
More information about the MapServer-users
