[mapserver-users] Tinyows exchange coords when POST request.
Andrea Peri
aperi2007 at gmail.com
Tue Mar 15 13:16:03 PDT 2016
thx to Olivier. I understand that the TinyOWS has a rule inherited from OGC that
when the srs is in short version (ie: EPSG:3003) the axis are not reversed.
Instead when the srs is with long form (ie:
urn:x-ogc:def:crs:EPSG:3003) the axis are always reversed.
A last question I have is about the input.
Infact this rule seem to be supported also in input request.
So when the srs is espressed in the request in long form , I guess,
the cocordinates should be given in reversed order.
But instead tinyows seem to accept instead the coordinate in not
reversed axis order.
I post a sample :
This is the post example:
<?xml version="1.0" encoding="UTF-8"?><wfs:GetFeature
xmlns:sita="http://www.regione.toscana.it/"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ows="http://www.opengis.net/ows"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml" handle="GeoTools 11.4 WFS
DataStore" maxFeatures="10" outputFormat="text/xml; subtype=gml/3.1.1"
resultType="results" service="WFS" version="1.1.0">
<wfs:Query srsName="urn:ogc:def:crs:EPSG::3003"
typeName="sita:listacomunirtpoly">
<ogc:Filter>
<ogc:Intersects>
<ogc:PropertyName>geometry</ogc:PropertyName>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:3003">
<gml:exterior>
<gml:LinearRing srsDimension="2">
<gml:posList>1625601.65 4842775.06 1696384.15 4842775.06
1696384.15 4871929.04 1625601.65 4871929.04 1625601.65
4842775.06</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ogc:Intersects>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
That is callable using this curl call:
curl -H "Content-Type: text/xml" -0 -X POST -d @req2.xml
"http://www502.regione.toscana.it/wfsvector/com.rt.wfs.RTmap/wfs"
As noticeable.
The request has the coords in not reversed order, the srs is in the
long form, and the response is with coords in reversed order.
I guess the tinyows should accept the coords in reversed order to be
totally coherent with the rule that the long srs form will reverse
axis.
Any thought ?
2016-03-14 17:00 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I experience this issue.
> When asking to the tinyows a getfeature with an intersects with a
> polygon and returning in epsg:3003 it return the result with the right
> axis order if the request is done with GET method.
> Instead it return exchange coords if the request is in POST method.
> Is know this issue ?
> Thx.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
