[mapserver-users] Oracle Layer: how to set context prior to fetching the data
Dan Little theduckylittle at gmail.com
Thu Mar 24 06:21:46 PDT 2016
The other option is to create yet-another stored procedure wrapper.  In the
Mapfile, you'd call the special wrapper stored procedure and it would
return the rows to map.
On Thu, Mar 24, 2016 at 8:16 AM, Jeff McKenna <jmckenna at gatewaygeomatics.com
> wrote:
> Hi Martin,
> Have you tried using a virtual spatial layer (.ovf) file to manage this?
> You can include a "<SrcSQL>" tag to run your stored procedure.  See
> examples at http://mapserver.org/input/vector/VirtualSpatialData.html
> More details of that driver at: http://www.gdal.org/drv_vrt.html
> Otherwise, I have seen others on this mailing list use stored procedures
> in the DATA statement of the mapfile, such as:
> DATA "the_geom from (select the_geom, id, name, myprocedure() as style
> from states) as foo using srid=4326 using unique id"
> Maybe the ovf is the way to go for your case, not sure.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2016-03-24 6:59 AM, Martin Icking wrote:
>> One of the Oracle based sources we are publishing is using Oracle context
>> variables to enable Oracle's fine grained access control.
>> So we are in the need to set these context variables (e.g. current
>> username)
>> prior to doing the select defined by MapServer's DATA statement. In other
>> applications we do that by calling a set_context (...) stored procedure
>> prior to any data requests.
>> Is there any possibility in MapServer to send a pre-request statement to
>> the
>> database? A current work-around is to set the context at logon time but
>> that
>> means that we need a new logon for every request that needs a different
>> user
>> context, not optimal for websites with many users. We'd prefer to have a
>> single logon that can be re-used for all requests.
>> If there is currently no way to handle this in MapServer we'd like to
>> extend
>> the Oracle layer's capabilities. Any suggestion by the MS developers on
>> where we should place the needed extension in the mapfile (e.g. adding an
>> additional keyword at the USING part of the data statement or using new
>> layer metadata)?
>> Any interest in generalizing this approach?
>> Tx
>> Martin
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160324/ae18576e/attachment.htm>
More information about the MapServer-users mailing list
