[mapserver-users] WFS - featureid/resourceid
Ian Walberg
ian.walberg at airborne.aero
Sat May 7 12:43:51 PDT 2016
Yes we see the same and that was my reason for asking.
Thanks
Ian
Sent: Saturday, May 7, 2016 12:39 PM
To: Ian Walberg <ian.walberg at airborne.aero>
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WFS - featureid/resourceid
Well it looks like your map file settings are fine, and a correctly formatted URL would be:
http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&STOREDQUERY_ID=urn:ogc:def:query:OGC-WFS::GetFeatureById&ID=DATA_TEST.1
However the resulting error message indicates that something may else may be amiss:
msQueryByFilter(): Search returned no results. No matching record(s) found.
LayerDefaultTranslateFilter(): General error message. This data driver does not implement filter translation support
On Sat, May 7, 2016 at 12:29 PM, Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>> wrote:
And also in the WEB section
METADATA
"wfs_title" "WFS Test"
"wfs_onlineresource" "http://127.0.0.1/cgi-bin/mapserv?"
"wfs_srs" "EPSG:4326"
"wfs_abstract" "WFS Test"
"wfs_enable_request" "*"
"wfs_getfeature_formatlist" "geojson"
Ian
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Ian Walberg
Sent: Saturday, May 7, 2016 12:27 PM
To: TC Haddad <tchaddad at gmail.com<mailto:tchaddad at gmail.com>>
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Here is what we have in the map file layer, what have we missed?
METADATA
"wfs_title" "DATA_POI"
"gml_featureid" "id"
"gml_include_items" "all"
"wfs_encoding" "UTF-8"
"wfs_abstract" "Points"
END
Thanks
Ian
Sent: Saturday, May 7, 2016 12:12 PM
To: Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>>
Cc: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Ian
you may have to enable the GetFeatureById option in your mapfile as at the moment it looks like you have it turned off.
Put something like this in the LAYER block to enable all WFS requests:
From there you can begin to test with:
http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeatureById
And the server will tell you what other parameters you need to add to the URL in order to successfully return a record.
On Sat, May 7, 2016 at 11:44 AM, Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>> wrote:
Jukka,
We could not get that to work, what is the syntax for our setup?
Thanks
Ian
From: Rahkonen Jukka (MML) [mailto:jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>]
Sent: Saturday, May 7, 2016 10:54 AM
To: Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>>; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: VS: [mapserver-users] WFS - featureid/resourceid
I would try the GetFeatureById stored query http://mapserver.org/ogc/wfs_server.html
Jukka Rahkonen
Lähettäjä: Ian Walberg<mailto:ian.walberg at airborne.aero>
Lähetetty: 7.5.2016 20:47
Vastaanottaja: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Aihe: [mapserver-users] WFS - featureid/resourceid
Folks,
How do we select just a single feature using FEATUREID or RESOUCEID.
http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=DATA_TEST
Thanks
Ian
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160507/e777e7d3/attachment-0001.html>
