[mapserver-users] WFS - featureid/resourceid
TC Haddad
tchaddad at gmail.com
Sat May 7 13:13:34 PDT 2016
Do you have a FILTERITEM specified in the LAYER?
See this thread to see if the solution helps:
http://lists.osgeo.org/pipermail/mapserver-users/2015-June/077933.html
On Sat, May 7, 2016 at 1:04 PM, Ian Walberg <ian.walberg at airborne.aero>
wrote:
> The db is sqlite.
> ian
> *From:* TC Haddad [mailto:tchaddad at gmail.com]
> *Sent:* Saturday, May 7, 2016 12:57 PM
> *To:* Ian Walberg <ian.walberg at airborne.aero>
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] WFS - featureid/resourceid
> No - it seems the result could return successfully in either format, so
> the server config is fine.
> What is the data storage format? perhaps that is the driver that is
> reporting the error...
> On Sat, May 7, 2016 at 12:53 PM, Ian Walberg <ian.walberg at airborne.aero>
> wrote:
> That did not seem to make any difference, can you tell from here what
> output types should work?
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetCapabilities
> Thanks
> Ian
> *From:* TC Haddad [mailto:tchaddad at gmail.com <tchaddad at gmail.com>]
> *Sent:* Saturday, May 7, 2016 12:46 PM
> Try adding GML as a format option to see if you are able to get a result
> that way:
> "wfs_getfeature_formatlist" "gml,geojson"
> On Sat, May 7, 2016 at 12:43 PM, Ian Walberg <ian.walberg at airborne.aero>
> wrote:
> Yes we see the same and that was my reason for asking.
> Thanks
> Ian
> *Sent:* Saturday, May 7, 2016 12:39 PM
> Well it looks like your map file settings are fine, and a correctly
> formatted URL would be:
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&STOREDQUERY_ID=urn:ogc:def:query:OGC-WFS::GetFeatureById&ID=DATA_TEST.1
> However the resulting error message indicates that something may else may
> be amiss:
> msQueryByFilter(): Search returned no results. No matching record(s) found.
> LayerDefaultTranslateFilter(): General error message. This data driver
> does not implement filter translation support
> On Sat, May 7, 2016 at 12:29 PM, Ian Walberg <ian.walberg at airborne.aero>
> wrote:
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160507/b76e193f/attachment.html>
