[mapserver-users] WFS - featureid/resourceid
aperi2007
aperi2007 at gmail.com
Sat May 7 13:46:10 PDT 2016
Perhaps the mapserver need a validation block in mapserver to check the
ID value from parameter ?
A.
Il 07/05/2016 21:39, TC Haddad ha scritto:
> Well it looks like your map file settings are fine, and a correctly
> formatted URL would be:
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&STOREDQUERY_ID=urn:ogc:def:query:OGC-WFS::GetFeatureById&ID=DATA_TEST.1
> However the resulting error message indicates that something may else
> may be amiss:
> msQueryByFilter(): Search returned no results. No matching record(s)
> found.
> LayerDefaultTranslateFilter(): General error message. This data driver
> does not implement filter translation support
> On Sat, May 7, 2016 at 12:29 PM, Ian Walberg
> <ian.walberg at airborne.aero <mailto:ian.walberg at airborne.aero>> wrote:
> And also in the WEB section
> METADATA
> "wfs_title" "WFS Test"
> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/mapserv?"
> "wfs_srs" "EPSG:4326"
> "wfs_abstract" "WFS Test"
> "wfs_enable_request" "*"
> "wfs_getfeature_formatlist" "geojson"
> Ian
> *From:*mapserver-users
> [mailto:mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>] *On Behalf Of
> *Ian Walberg
> *Sent:* Saturday, May 7, 2016 12:27 PM
> *To:* TC Haddad <tchaddad at gmail.com <mailto:tchaddad at gmail.com>>
> *Cc:* mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> *Subject:* Re: [mapserver-users] WFS - featureid/resourceid
> Here is what we have in the map file layer, what have we missed?
> METADATA
> "wfs_title" "DATA_POI"
> "gml_featureid" "id"
> "gml_include_items" "all"
> "wfs_encoding" "UTF-8"
> "wfs_abstract" "Points"
> END
> Thanks
> Ian
> *From:*TC Haddad [mailto:tchaddad at gmail.com]
> *Sent:* Saturday, May 7, 2016 12:12 PM
> *To:* Ian Walberg <ian.walberg at airborne.aero
> *Cc:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>>;
> Ian
> you may have to enable the GetFeatureById option in your mapfile
> as at the moment it looks like you have it turned off.
> Put something like this in the LAYER block to enable all WFS requests:
> From there you can begin to test with:
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeatureById
> And the server will tell you what other parameters you need to add
> to the URL in order to successfully return a record.
> On Sat, May 7, 2016 at 11:44 AM, Ian Walberg
> Jukka,
> We could not get that to work, what is the syntax for our setup?
> Thanks
> Ian
> *From:*Rahkonen Jukka (MML)
> [mailto:jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>]
> *Sent:* Saturday, May 7, 2016 10:54 AM
> <mailto:ian.walberg at airborne.aero>>;
> *Subject:* VS: [mapserver-users] WFS - featureid/resourceid
> I would try the GetFeatureById stored query
> http://mapserver.org/ogc/wfs_server.html
> Jukka Rahkonen
> *Lähettäjä: *Ian Walberg <mailto:ian.walberg at airborne.aero>
> *Lähetetty: *7.5.2016 20:47
> *Vastaanottaja: *mapserver-users at lists.osgeo.org
> *Aihe: *[mapserver-users] WFS - featureid/resourceid
> Folks,
> How do we select just a single feature using FEATUREID or
> RESOUCEID.
> http://wfs-dev.airborne.aero/cgi-bin/mapserv?map=/data/wfs/WFS_TEST.map&SERVICE=WFS&VERSION=2.0.0&REQUEST=GetFeature&TYPENAMES=DATA_TEST
> Thanks
> Ian
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160507/48f09cfa/attachment-0001.html>
