[mapserver-users] runtime CONNECTION string partial substitution
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon May 16 06:59:21 PDT 2016
I am by no means a master with regexp so I took the validation [a-z]+ from the mail by Giovanni and tested it with the http://www.regexr.com/ tool.
I do understand now that if I do not include anchors ^and $ then it is enough the find one validated character and therefore [a-z]+ accepts “wms-wfs” even dash is not included in regexp. But why [a-z]+ is also accepting “WMS-WFS”? Shouldn’t it be case sensitive?
I made some more tests and these two variants accept both all lower case and all upper case strings on Windows with Mapserver 7.0 from MS4W:
VALIDATION
"db" "^[A-Z]+$"
END
VALIDATION
"db" "^[a-z]+$"
END
-Jukka Rahkonen-
Lähettäjä: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Lähetetty: 16. toukokuuta 2016 15:31
Vastaanottaja: Rahkonen Jukka (MML)
Kopio: MapserverList OSGEO; G. Allegri
Aihe: Re: [mapserver-users] runtime CONNECTION string partial substitution
Not sure I get it. Your regex requires a letter or a dash , and one of them is present, no?
On May 16, 2016 2:28 PM, "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Hi Thomas,
I was testing with http://www.regexr.com/ and it does not agree totally:
“wms-wfs” contains a dash and the test utility requires “[a-z-]+”
WMS-WFS has capital letters and dash and test utility requires “[A-Z-]+”
-Jukka-
Lähettäjä: thomas bonfort [mailto:thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>]
Lähetetty: 16. toukokuuta 2016 15:11
On May 16, 2016 2:02 PM, "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
> Correction:
> Changing the WMS online resource does work if the mapfile is written correctly. I had to add VALIDATION also into MAP->WEB
> WEB
> METADATA
> "wms_onlineresource" "http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w\apps\wms-wfs.map&db=%db%"
> END #metadata
> VALIDATION
> "db" "[a-z]+"
> END #validation
> END #WEB
> Now I can send
> http://localhost:8060/cgi-bin/mapserv.exe?map=c:/ms4w/apps/wms-wfs.map&service=wms&version=1.3.0&request=getcapabilities&db=wms-wfs
> and get
> <OnlineResource xlink:href="http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w\apps\wms-wfs.map&db=wms-wfs&"/>
> What is interesting is that the validation rule “[a-z]+” should not accept the name of my db “wms-wfs” but it does. Capital letters are accepted as well “WMS-WFS”. Because I am on Windows I can even get data with WMS-WFS though the name of the db is “wms-wfs.sqlite”.
That's because [a-z]+ means "there should be at least one alphabetic character in the passed expression". The " correct" regex to use would be ^[a-z]+$
Thomas
> -Jukka Rahkonen-
> Lähettäjä: Rahkonen Jukka (MML)
> Lähetetty: 16. toukokuuta 2016 14:24
> Vastaanottaja: 'G. Allegri'; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Hi,
> I made a test with your VALIDATION and CONNECTION and changing db on-the-fly works. How did you test? If you use some WMS client for testing it is good to remember that variable substitution does not have an effect on the GetCapabilities document so that the GetMap URL would be updated automatically. Therefore WMS clients like QGIS or OpenJUMP will drop the &db= parameter from the GetMaps if you do not tell them not to trust the advertised GetMap URL.
> According to documentation http://mapserver.org/cgi/runsub.html it should also be possible to use variable substitution also in MAP- WEB: METADATA. I tried
> to use
> "wms_onlineresource" “http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w\apps\wms-wfs.map&%db%”
> but GetCapabilities response contains the variable %db% literally
> <OnlineResource xlink:href="http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w\apps\wms-wfs.map&%db%&"/>
> It seems that for getting a proper error message when &db= is missing or it is wrong a WMS GetMap request is required. WFS GetFeature triggers the error
> and is easier to write by hand, for example:
> http://localhost:8060/cgi-bin/mapserv.exe?map=c:/ms4w/apps/wms-wfs.map&service=wfs&version=2.0.0&request=getfeature&typename=states&db=foo
> sends an error
> <ows:ExceptionText>
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `states'. File not found or unsupported format.
> </ows:ExceptionText>
> Document http://www.mapserver.org/optimization/debugging.html contains good advice for debugging.
> -Jukka Rahkonen-
> G. Allegri wrote:
> Hello,
> I'm trying to define a layer where the Sqlite DB connection should be set dynamically through runtime sustitution.
> e.g.
> LAYER
> NAME mylayer
> TYPE POINT
> CONNECTIONTYPE OGR
> VALIDATION
> "db" "[a-z]+"
> END
> CONNECTION "/var/www/dbs/%db%.sqlite"
> DATA "mytable"
> END
> The point layers works fine if %db% is set statically but if I try to define it through get query values nothing is returned:
> http://localhost/cgi-bin/mapserv?map=mymapfile.map&db=mydb
> The documentation says that runtime sustitution should work for CONNECTION param too. What am I doing wrong?
> Thanks,
> Giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> Gis3W - http://gis3w.it
> Ikare - http://ikare.it
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160516/f8bd0fdd/attachment-0001.html>
