[mapserver-users] openlayers 3
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon May 16 08:50:38 PDT 2016
Hello Hosain,
To help you and others get started with OpenLayers, I've added an
OpenLayers 3 example that uses a (local) WMS service, into MS4W's
OpenLayers package. The data is in spatialite format. What's nice is
that you can just use this working mapfile (that lives in
/ms4w/apps/openlayers/examples/map/wms-server.map) and its working
javascript code (visible through a link on the MS4W homepage at
127.0.0.1). Once you install MS4W 3.14 and the OpenLayers 3.15.1
package (from http://ms4w.com), look for a new "MapServer WMS Example"
on your MS4W homepage, under the "OpenLayers" section. This new demo
will look like this: http://pasteboard.co/Y63Qzix.jpg
If you use MS4W's setup.exe installer the mapfile and the OpenLayers
code will be automatically modified for your installation (path to
mapfile, WMS onlineresource, Apache port, etc.).
I think this will help you and others get started with OpenLayers3 and MS4W.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-05-16 4:29 AM, Yves Jacolin wrote:
> Hello,
> It could be two kind of problem:
> * server side
> * client site
> It is difficult to see a problem (except obvious one) in such code. Did you
> check that your mapserver is working correctly?
> If not check this:
> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/jask/jask.map&REQUEST=getcapabilities&SERVICE=WMS&VERSION=1.3.0
> If you get the capabilities, check any errors messages in the capabilities. If
> you can't have the capabitilies, try to find the error or post the error
> message if you can't find it.
> When WMS service works, you can try the ol3 mailing list to see why the client
> side is not working.
> Regards,
> Y.
> On Friday, May 13, 2016 11:54:55 hosain mohammadi wrote:
>> hello
>> i'd like to use openlayers3 for wms service
>> the belowe code is correct?
>> <!doctype html>
>> <html lang="en">
>> <head>
>> <link rel="stylesheet"
>> href="http://openlayers.org/en/v3.15.1/css/ol.css" type="text/css">
>> <style>
>> .map {
>> height: 100%;
>> width: 100%;
>> </style>
>> <script src="http://openlayers.org/en/v3.15.1/build/ol.js"
>> type="text/javascript"></script>
>> <title>web gis</title>
>> </head>
>> <body>
>> <div id="map"></div>
>> <script type="text/javascript">
>> var layers = [
>> new ol.layer.Image({
>> extent: [1062293,17704892,1085747,17720997],
>> source: new ol.source.ImageWMS({
>> url: '
>> params: {
>> 'LAYERS': 'jask',
>> 'CRS': 'EPSG:4326',
>> 'BBOX': '1062293,17704862,1085747,17720997',
>> 'FORMAT': 'image/png',
>> 'mode':'map'
>> serverType: 'mapserver'
>> var projection = new ol.proj.Projection({
>> code: 'EPSG:4326',
>> units: 'm'
>> var map = new ol.Map({
>> layers: layers,
>> target: 'map',
>> controls: [
>> new ol.control.Zoom(),
>> new ol.control.ZoomSlider()
>> view: new ol.View({
>> center: [1073136.94,17716190.89],
>> zoom: 13,
>> projection: projection
>> </script>
>> </body>
>> </html>
>> someone has offer?
