[mapserver-users] MS4W and Oracle
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed May 18 16:14:40 PDT 2016
Hi Ricardo,
Can you test with a mapfile (not mapscript)? Then use the shp2img
commandline utility to test your mapfile.
In my Oracle instance, the default spatial column is named
"ORA_GEOMETRY", so my DATA parameter in my mapfile layer looks like:
DATA "ORA_GEOMETRY FROM (SELECT ORA_GEOMETRY FROM PARK)"
You can also see the full SQL used by MapServer, through your shp2img
command such as:
shp2img -m oracle.map -o ttt.png -all_debug 3
Look for the lines around "msOracleSpatialLayerWhichShapes. Using this
Sql to retrieve the data" in the response.
Another alternative, is to check how GDAL/OGR sees your Oracle table.
Follow the steps to configure your MS4W (step 3 at
http://ms4w.com/README_INSTALL.html#oracle-10g-11g-12c), then try to
connect through ogrinfo:
ogrinfo -ro OCI:jeff/pass at tnsname LAYERNAME -summary
I hope this gives you some ideas for your problem.
Thanks for using MS4W, and hello from the east coast of Canada! :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-05-18 9:48 AM, Ricardo Queiroz wrote:
> This is my first mail to this list, and sorry about english (not my
> native language)
> I've a software with ms4w 1.3.4 and pgsql9.5 (and postgis 2.2.2) and
> works fine, so i need to convert all the app to use oracle (client
> request =/, i'm using oracle client 11.2.0.3.0). I follow the steps of
> the ms4w installation and when write "mapserv -v" in console the
> oraclespatian appears, so the next step was test the connection layer,
> there's ok, when i change some parameters (to wrong) in the conn string
> the connect fail, but here's the problem, when i set a data in the layer
> (simple sql) allways return a error and i can't resolve this, don't know
> if is some mapserver config or else.
> Basic example of layer (trying draw a point):
> $objLayer = ms_newLayerObj($objMap);
> $objLayer ->set("name", "layer_oracle");
> $objLayer ->setConnectionType(MS_ORACLESPATIAL);
> $objLayer ->set("connection", "user/pass at tnsName");
> $objLayer ->setProcessing("CLOSE_CONNECTION=DEFER");
> $objLayer ->set("type", MS_LAYER_POINT);
> $data = "THE_GEOM from (select PK_ID, NAME as LABELITEM, THE_GEOM
> from user.TABLE_POINT) USING SRID 29193";
> $objLayer ->set("data", $data); unset($data);
> $objLayer ->set("labelitem", "LABELITEM");
> $objLayer ->set("template", "layer.html");
> $objLayer ->set("header", "layer.html");
> $objLayer ->set("footer", "layer.html");
> $objClass= ms_newClassObj($objLayer );
> $objClass->set("name", "POINT");
> $objStyle= ms_newStyleObj($objClass);
> $objStyle->set("symbolname", "dot_purple");
> $objLabel= new labelObj();
> $objLabel->color->setRGB(217, 242, 230);
> $objLabel->outlinecolor->setRGB(0, 0, 0);
> $objLabel->set("font", "luxi-bold");
> $objLabel->set("size", 9);
> $objLabel->set("position", MS_UC);
> $objLabel->set("partials", MS_TRUE);
> $objLabel->set("mindistance",100);
> $objLabel->set("buffer",4);
> $objClass->addLabel($objLabel);
> $objLayer ->set("status", MS_ON);
> $objLayer ->free(); $objClass->free(); $objStyle->free();
> $objLabel->free();
> unset($objLayer); unset($objClass); unset($objStyle); unset($objLabel);
> I get the error message:
> Warning: mapObj::draw(): [MapServer Error]: msDrawMap(): Failed to
> draw layer named 'layer_oracle'. in...
> msOracleSpatialLayerWhichShapes(): Check your data statement and
> server logs in...
> When i change some var on set("connection") i get the error conn msg, so
> i can connect, just can't draw the point
> msOracleSpatialLayerOpen(): Cannot create OCI Handlers. Connection
> failure. Check your logs and the connection string. in
> The same example works fine when i change to postgis (using the same
> table "structure").
> Oracle table and the record:
> CREATE TABLE TABLE_POINT
> PK_ID NUMBER,
> NAME VARCHAR2(30 BYTE),
> THE_GEOM SDO_GEOMETRY,
> PRIMARY KEY (PK_ID)
> insert into TABLE_POINT(PK_ID, NAME, THE_GEOM) values(1, 'Point
> 1', MDSYS.SDO_GEOMETRY(2001,29193,MDSYS.SDO_POINT_TYPE(798062.7655190326,7459237.923282569,null),null,null));
> Thanks,
> Ricardo Queiroz
