[mapserver-users] Mapserver - connection to MSSQL
Tamas Szekeres
szekerest at gmail.com
Tue May 31 14:23:20 PDT 2016
Probably the referred table is not enumerated in the geometry_columns
metadata table of the database.
Best regards,
Tamas
2016-05-31 23:04 GMT+02:00 Robert Sanson <Robert.Sanson at asurequality.com>:
> Hi Tamas
> Thanks for that. I tried that but now the response is:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM "
> http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'par_direct'.
> msOGRFileNextShape(): OGR error. Error initializing the metadata tables :
> </ServiceException>
> </ServiceExceptionReport>
> Any way I can get around this issue?
> Robert
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Wednesday, 1 June 2016 6:36 a.m.
> *To:* Robert Sanson <Robert.Sanson at asurequality.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Mapserver - connection to MSSQL
> Robert,
> It looks like the port number portion in the connection string causes the
> issue, specifically the comma is not being interpreted correctly by the
> parser. I guess this is similar to an earlier issue reported to gdal:
> https://trac.osgeo.org/gdal/ticket/4885
> That time quoting the connection string provided a workaround as far as I
> remember.
> Best regards,
> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160531/8f4a7950/attachment-0001.html>
