[mapserver-users] arcgis 10.3 enterprise geodatabase
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Thu Nov 3 13:02:48 PDT 2016
If GDAL/OGR can handle the format then you’re in luck. I’d check there first…
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Oscar ^_^
Sent: Thursday, November 03, 2016 2:51 PM
To: Wingfield, Nathaniel D <nw at dcp.ufl.edu>
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] arcgis 10.3 enterprise geodatabase
I've got the same requeriment althought i can use 10.1 or 10.2 but i don't know how to implement these to Mapserver....
Any suggestion o guide ??
2016-11-01 7:39 GMT-06:00 Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>:
Can MapServer consume spatial data from an ArcGIS 10.3 enterprise geodatabase? We are using the default SDE.ST_GEOMETRY type, on Oracle. The MapServer docs indicate that any support for ESRI enterprise geodatabases is based on ArcSDE, which was abandoned by ESRI at version 10.3, in favor of direct connect (https://blogs.esri.com/esri/supportcenter/2015/02/11/where-is-the-install-for-arcsde-10-3/).
We will likely use OpenLayers for a new web-based mapping app, so MapServer seems like a natural choice (otherwise we will have to use ArcGIS Server).
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
OSCAR
^_^
Y
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161103/4edd5030/attachment.html>
