[mapserver-users] arcgis 10.3 enterprise geodatabase
    Wingfield, Nathaniel D
    nw at dcp.ufl.edu
    Fri Nov  4 10:38:27 PDT 2016
That's good to know. I really enjoyed using SDO_GEOMETRY in the past. I will take a closer look to see if we can do everything we need to do with Locator. I'll also jump over to the GDAL list for confirmation about the enterprise geodatabase.
From: Michael Smith [mailto:michael.smith.erdc at gmail.com]
Sent: Friday, November 04, 2016 1:08 PM
To: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; Wingfield, Nathaniel D <nw at dcp.ufl.edu>; Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>; Oscar ^_^ <oscarfbh at gmail.com>
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] arcgis 10.3 enterprise geodatabase
MapServer does not use any oracle spatial calls, just locator. There is no extra cost need to use mapserver with Oracle SDO_GEOMETRY data.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: "Rahkonen Jukka (MML)" <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>
Date: Friday, November 4, 2016 at 12:09 PM
To: "Wingfield, Nathaniel D" <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>, Michael Smith <michael.smith.erdc at gmail.com<mailto:michael.smith.erdc at gmail.com>>, "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>, Oscar ^_^ <oscarfbh at gmail.com<mailto:oscarfbh at gmail.com>>
Cc: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Are you sure that you would need Spatial? Locator covers nowadays most use cases.
-Jukka Rahkonen-
Lähettäjä: Wingfield, Nathaniel D<mailto:nw at dcp.ufl.edu>
Lähetetty: 4.11.2016 18:00
Vastaanottaja: Michael Smith<mailto:michael.smith.erdc at gmail.com>; Lime, Steve D (MNIT)<mailto:Steve.Lime at state.mn.us>; Oscar ^_^<mailto:oscarfbh at gmail.com>
Kopio: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Aihe: Re: [mapserver-users] arcgis 10.3 enterprise geodatabase
That's a great approach, but sadly the Oracle Spatial licensing is out of reach for us.
Almost 10 years ago, I used SDO_GEOMETRY with ArcSDE but it was rather buggy on the ESRI side. I wonder if their support has improved?
Sent: Thursday, November 03, 2016 4:08 PM
To: Lime, Steve D (MNIT) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>; Oscar ^_^ <oscarfbh at gmail.com<mailto:oscarfbh at gmail.com>>; Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
The other option, which is what we use, is to store ArcGIS 10.3 enterprise data as SDO_GEOMETRY native. We find no performance penalties in ArcGIS and performance benefits for non-esri software, such as mapserver.
Mike
Michael Smith
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> on behalf of "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
Date: Thursday, November 3, 2016 at 4:02 PM
To: Oscar ^_^ <oscarfbh at gmail.com<mailto:oscarfbh at gmail.com>>, "Wingfield, Nathaniel D" <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>
If GDAL/OGR can handle the format then you're in luck. I'd check there first...
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Oscar ^_^
Sent: Thursday, November 03, 2016 2:51 PM
To: Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>
I've got the same requeriment althought i can use 10.1 or 10.2 but i don't know how to implement these to Mapserver....
Any suggestion o guide ??
2016-11-01 7:39 GMT-06:00 Wingfield, Nathaniel D <nw at dcp.ufl.edu<mailto:nw at dcp.ufl.edu>>:
Can MapServer consume spatial data from an ArcGIS 10.3 enterprise geodatabase? We are using the default SDE.ST_GEOMETRY type, on Oracle. The MapServer docs indicate that any support for ESRI enterprise geodatabases is based on ArcSDE, which was abandoned by ESRI at version 10.3, in favor of direct connect (https://blogs.esri.com/esri/supportcenter/2015/02/11/where-is-the-install-for-arcsde-10-3/).
We will likely use OpenLayers for a new web-based mapping app, so MapServer seems like a natural choice (otherwise we will have to use ArcGIS Server).
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
OSCAR
^_^
 Y
_______________________________________________ mapserver-users mailing list mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161104/c5252f06/attachment.htm>
More information about the MapServer-users
