[mapserver-users] A problem with the Run-time substitution
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 7 06:32:05 PST 2016
Your SQL was missing the parenthesis, which I suppose to be mandatory with IN
http://www.1keydata.com/sql/sqlin.html
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Burgholzer, Robert (DEQ)
Lähetetty: 7. marraskuuta 2016 16:18
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] A problem with the Run-time substitution
By includiong the single quotes in the PROCESING directive, doesn't that make your input evaluated as a string? You example suggests that mapserver considers single quotes around the input to be bad and rejects it - but by putting single quotes in PROCESSING it should avoid that.
What does the expression look like when you tried to syntax I suggested?
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Janne Tuovinen
Sent: Monday, November 07, 2016 9:08 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] A problem with the Run-time substitution
Thank you, but this doesn't work for me. The problem is that I want to pass a string value to my database, but the MapServer doesn't allow that and always passes the parameters value as an integer.
-Janne
11/7/2016, 3:33 PM, Burgholzer, Robert (DEQ) wrote:
> I believe that what you want is this:
> PROCESSING "NATIVE_FILTER=param in '%param%' "
> I have not used the processing directive, so can not be sure, but the above syntax would work in a QUERY.
> Sent: Monday, November 07, 2016 7:36 AM
> Subject: [mapserver-users] A problem with the Run-time substitution
> Hi,
> I have a problem when I'm trying to pass a url-parameter to Postgis query's NATIVE_FILTER in my map file.
> My layer looks something like this:
> LAYER
> VALIDATION
> 'param' '.+'
> END
> DATA "shape from table"
> PROCESSING "NATIVE_FILTER=param in %param%"
> END # LAYER
> Here is some examples what I get when I try to pass some values:
> ...¶m=1000 = > (param in (1000))
> ...¶m='1000' = > (param in (%param%))
> What I like to have is: (param in ('1000'))
> Is there a way to this with the MapServer 7.0?
> Thank you,
> Janne
