[mapserver-users] GetFeatureInfo layout in plain text
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Nov 10 04:02:40 PST 2016
humm, good point, I need to check the output request from ArcGIS. The users
said that for other service they get a table, so probably an html format.
Thanks,
Y.
2016-11-10 12:59 GMT+01:00 Jörg Thomsen (WhereGroup) <
joerg.thomsen at wheregroup.com>:
> so, what do you have to style? Perhaps you could create a text-format
> output with templates to create a sort of ascii-tables, you don't have
> to use html-tags within the templates. But in this case the request has
> to be format=text/html.
> Jörg
> Am 10.11.2016 um 12:39 schrieb Yves Jacolin:
> > Thanks Jörg,
> > Unfortunately I should use text format as ArcGIS desktop don't support
> other
> > format (to be confirmed).
> > Y.
> > On Thursday, November 10, 2016 11:49:49 Jörg Thomsen wrote:
> >> Hi Yves,
> >> text/plain is text/plain, no layout. The Mapserver-templates work with
> >> html-format. Another way could be using the xml-output and styling it
> >> with xslt. But you can enable the html-output using templates with
> >> mapserver and it still will be possible to send text/plain requests.
> >> Templating ist easy and powerful, so to answer your question: yes, read
> >> the templating chapter. You'll find a short introduction in the old
> >> tutorial: http://demo.mapserver.org/tutorial/section3.html (example
> 3.1)
> >> Jörg
> >> Am 10.11.2016 um 11:16 schrieb Yves Jacolin:
> >>> Hello,
> >>> I have to setup a text format for a WMS' GetFeatureInfo service. I
> would
> >>> like to know if it is possible to change the layout using a template.
> >>> My first test was not working so any feedback is welcome. The
> >>> documentation
> >>> said that the user should read the templating chapter so I guess this
> is
> >>> possible.
> >>> Any confirmation?
> >>> Y.
> >> Viele Grüße,
> >> Jörg Thomsen
> Viele Grüße,
> Jörg Thomsen
> Where2B Konferenz 2016
> 15. Dezember 2016 in Bonn
> www.where2b-conference.com
> Jörg Thomsen
> WhereGroup GmbH & Co. KG
> Gillweg 3
> 14193 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 89 09 53 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> mapserver-users at lists.osgeo.org
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 58 48 20 43 (new !)
Tel (Suisse) : +41 21 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161110/296e31cf/attachment.html>
