[mapserver-users] MapServer IIS7
Vogt, Robert (RCIS)
Robert.Vogt at rcis.com
Thu Oct 13 07:12:27 PDT 2016
Good morning,
I originally set up MapServer with WS4W and Apache server...I now have a requirement to put this on the same domain as our application which runs in IIS7.
I have created the site and pointed my application at it and the results are mixed...
Map files that are pointed at lizardtech for their source are working but map files that are pointed at SQL for their source are giving a 502(bad gateway) error.
All map files worked when served through Apache, has anyone run into this or know what I should look at to fix it?
Your help is greatly appreciated!!
******** Map File ***************************
MAP
IMAGETYPE PNG24
CONFIG "PROJ_LIB" "E:/RCIS/Web/MapServerDlls/projlib"
SIZE 256 256
FONTSET "E:/RCIS/Web/MapServerDlls/content/fontset.txt"
IMAGECOLOR 255 255 255
TRANSPARENT ON
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
"wms_title" "sections"
"wms_enable_request" "*"
END
END
LAYER
NAME "States"
TYPE POLYGON
STATUS ON
LABELCACHE ON
PROCESSING 'LABEL_NO_CLIP=1'
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION "OurConnectionString"
DATA "shape(geography),ST_NAME_MC from NATIONALDB.sde.STATES USING INDEX STATES_SIDX USING UNIQUE STATES_ID USING SRID=4269"
LABELITEM "ST_NAME_MC"
PROCESSING "CLOSE_CONNECTION=DEFER"
CLASS
STYLE
OUTLINECOLOR 000 153 000
WIDTH 3
END
LABEL
COLOR 000 153 000
TYPE TRUETYPE
FONT Arial
SIZE 12
ANTIALIAS FALSE
POSITION AUTO
PARTIALS FALSE
END
END
PROJECTION
"init=epsg:4326"
END
END
END
