[mapserver-users] Need examples of UTFGrid Mapserver + Ol3
Soline Villermois
villermois.soline at gmail.com
Thu Oct 27 02:30:53 PDT 2016
'm having troubles using utfgrid module with openlayers. The implementation
on Mapserver's side is quite simple, even if i have doubts about the
imagetype :
MAP
IMAGETYPE UTFGRID
SIZE 2000 2000
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
#DEBUG 4
EXTENT -176.197 -31.0869 181.47 81.8381
NAME "allexmaple"
PROJECTION
"init=epsg:4326"
END
QUERYMAP
STATUS ON
END
OUTPUTFORMAT
NAME "utfgrid"
DRIVER UTFGRID
MIMETYPE "application/json"
EXTENSION "json"
FORMATOPTION "UTFRESOLUTION=4"
FORMATOPTION "DUPLICATES=false"
END
WEB
IMAGEPATH "tmp/"
IMAGEURL "tmp/"
END
SYMBOL
NAME "mysymbol"
TYPE pixmap
ANCHORPOINT 0.5 0.5
IMAGE "icons/mysymbol.png"
END
LAYER
TOLERANCE 10
CONNECTIONTYPE postgis
NAME "example"
CONNECTION "host=127.0.0.1 dbname=ais_data user=postgres
password=admin port=5432"
DATA "geom from mytable using srid=4326"
STATUS ON
TYPE POINT
UTFITEM "id"
UTFDATA "{\"id\":\"[id]\",\"name\":\"[name]\"}"
TEMPLATE 'query.html'
HEADER 'header.html'
FOOTER 'footer.html'
CLASSITEM "ct"
CLASS
EXPRESSION "mysymbol"
STYLE
ANGLE [angle]
SYMBOL 'mysymbol'
END # style
END # class
END
END
Openlayers, on the other hand, doesn't have efficient example. I don't know
what to provide in my url. Here's what I tried:
var gridSource = new ol.source.TileUTFGrid({
url: 'http://localhost:5000/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/essai.map&layers=example&tiled=true&mode=map&type=utfgrid&format=application/json'
var mySuperLayer = new ol.layer.Tile({
source: gridSource
But nothing appears and my url stays in pending until timeout
I just don't know how to debug that, any help would be highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161027/c2070596/attachment-0001.html>
