[mapserver-users] Fwd: [Qgis-user] Wrong retrieving of wms legend
Andrea Peri
aperi2007 at gmail.com
Fri Sep 16 13:44:36 PDT 2016
It is done using two layer. Mutually exclusive each other for scale
and grouped using the "wms_layer_group" setting.
LAYER
NAME "rt_ofc.10k88"
STATUS OFF
EXTENT 545379 4673155 776461 4927945
TYPE raster
TILEINDEX '/path-to/raster/ofc_1988_10k_bn/tiff_tiled/index_tiled'
TILEITEM 'location'
PROCESSING "BANDS=1"
PROCESSING "NODATA=0"
METADATA
"wms_title" "OFC 1988"
"wms_abstract" "..."
"wms_layer_group" "/rt_ofc.10k88"
END
MAXSCALEDENOM 128100
MINSCALEDENOM 1
# the color index for transparent
OFFSITE 0 0 0
# the global opacity (100=full opaque)
OPACITY 100
END
LAYER
NAME "rt_ofc.10k88.lite"
STATUS OFF
TYPE raster
TILEINDEX '/path-to/ofc_1988_10k_bn/tiff_tiled_lite_version/index_tiled'
TILEITEM 'location'
# ... other standard raster processing functions here
METADATA
"wms_title" "OFC 1988 Lite"
"ows_enable_request" "!GetCapabilities"
END
MAXSCALEDENOM 5000000
MINSCALEDENOM 128100
OFFSITE 0 0 0
OPACITY 100
END
LAYER
NAME "rt_ofc.10k88.qu"
STATUS OFF
TYPE POLYGON
DATA '/home/raster/ofc_1988_10k_bn/tiff_tiled/index_tiled'
PROJECTION
"init=epsg:25832"
END
METADATA
"wms_title" "OFC 1988 Quadro di unione"
"wms_extent" "545379.0 4673155.0 776461.0 4927945.0"
"wms_bbox_extended" "true"
"ows_include_items" "all"
"gml_include_items" "all"
"ows_enable_request" "*"
"gml_geometries" "GEOMETRY"
"ows_geomtype" "MultiPolygon"
"gml_geometry_type" "multipolygon"
"gml_types" "none"
"gml_PK_UID_type" "int"
END
MINSCALEDENOM 1
OPACITY 100
PROCESSING "APPROXIMATION_SCALE=FULL"
CLASS
NAME 'Quadro unione ofc 1988'
TEXT '[NAME]'
LABEL
END
STYLE
END
END
END
2016-09-16 19:08 GMT+02:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
> Indeed it does - interesting feature! What does the layer definition for rt_ofc.10k88 look like?
> -----Original Message-----
> From: Andrea Peri [mailto:aperi2007 at gmail.com]
> Sent: Friday, September 16, 2016 9:55 AM
> To: Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Fwd: [Qgis-user] Wrong retrieving of wms legend
> The question s about the legend retrieved from qgis using a
> getlegendgraphic request when add a wms to a canvas.
> The trouble is issuing when the ortophoto is grouped using a
> "wms_layer_group" setting and has no any style defined in it.
> As example, you can you try to connect to our mapserver wms of
> ortophotos using the last qgis 2.16 or 2.14.5 ?
> This is the url:
> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc
> and the layer to choose is the "rt_ofc.10k88"
> As you can see the qgis will retrieve ALL the legends of ALL the
> vector layers available in the same wms service.
> I don't understand if the wrong response is from mapserver or from
> qgis that wrongly require the legend to the parent layer, rretrieving
> so all the legends from all the layers availables.
> A.
> And add to a empty canvas the
> 2016-09-16 16:35 GMT+02:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
>> Hi Andrea: I guess I'm not sure exactly what you're asking. With latest/greatest QGIS raster WMS layers (e.g. aerial photos) show up fine in the QGIS legend if I have a KEYIMAGE set in the layer object. --Steve
>> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
>> Sent: Thursday, September 08, 2016 8:11 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Fwd: [Qgis-user] Wrong retrieving of wms legend
>> Hi post here a response from the qgis-user list about a question on
>> the GetLegendGraphics.
>> With the last version of qgis, when try to add in qgis a layer wms of
>> kind RASTER the qgis retrieve the legend OF ALL the layer available in
>> the service.
>> I guess this was a bug. But instead as the qgis guys response me seem
>> to be a right action.
>> The question seem that a layer wms should aALWAYS return a style. So
>> the question I guess is more interesting for the mapserver list:
>> A WMS LAYER of kind IMAGE (a catalogue of ortophoto as example) should
>> always have a style ?
>> (sorry for long thread repost, but I guess is better to post all the
>> discussion to help understand)
>> Thx,
>> Andrea.
>> 2016-09-08 14:45 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
>>> Hi Andrea,
>>> note that I also added a comment at the code which is reponsible for this:
>>> https://github.com/qgis/QGIS/commit/69bed218373b3f93671f65bc3d02c45cbf683a48#comments
>>> Patrick's response there on this (see comment):
>>> IMHO, there is nothing to fix in QGIS, here. If a layer defines no
>>> style, it's wanted that it inherits the parent layer's style. Have a
>>> look at chapter 7.2.4.6.5 of the WMS implementation specification:
>>> Style declarations are inherited by child Layers. A child shall not
>>> redefine a Style with the same Name as one
>>> inherited from a parent. A child may define a new Style with a new Name
>>> that is not available for the parent Layer.
>>> This PR is just a workaround for MapServer that is defining a style
>>> named default for both the parent and the child layers. This was making
>>> QGIS show 2 default styles for every child layers. Style inheritance was
>>> already there before. Now at has just a saner behavior in regard to
>>> non-standard compliant servers.
>>> I'll let you forward that to the user ML. I was not subscribed to it and
>>> therefore cannot reply directly to the thread.
>>> So in short: mapserver does not define a style for the actual layer, so
>>> qgis tries to get the style (AND it's legendgraphic) from the parent
>>> layer/node:
>>> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc&request=GetCapabilities&service=WMS
>>> in this case mapserver's rootnode, which has a legendgraphic with all
>>> child symbols...
>>> so my fix would be: define a style for the child layer 'rt_ofc.10k54',
>>> so I do not think it has something to do with the dot in the naming?
>>> Regards,
>>> On 03-09-16 20:42, aperi2007 wrote:
>>>> Hi Richard,
>>>> I tested also the QGIS 2.8 and the QGIS 2.12 no one of them has this issue.
>>>>>Bingo: that is the one we are actually retrieving, the parent node's
>>>>> style and legend.
>>>>> So: not sure if that is desired behaviour... at least not for a legend..
>>>> Ok, now is more clear what is happened.
>>>> The "rt_ofc" is the name of all the wms service.
>>>> So apply-ing the value "rt_ofc" to the layers parameter mean ask to the
>>>> wms server to send the response for ALL the layers available in the
>>>> service.
>>>> So the problem more probably is that qgis is failing to parse the
>>>> layername stopping it at the dot character.
>>>> The QGIS 2.8 and 2.12 don't fail to parse these wms layersname.
>>>> So it is due to some evolution put in the last qgis.
>>>> The "rt_oc" part of the layer name is also the name of all the wms service.
>>>> This will cause to receive the legend of ALL the layers.
>>>> A.
>>>> Il 03/09/2016 20:03, Richard Duivenvoorde ha scritto:
>>>>> Ok, at first the problem seemed the dot in the layernames:
>>>>> This is the GetMap request QGIS fires off:
>>>>> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc&map_resolution=91&language=ita&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=1063072.194008157123,5185232.179659257643,1388677.251798849553,5543677.86921980232&CRS=EPSG:3857&WIDTH=518&HEIGHT=569&LAYERS=rt_ofc.10k54&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE
>>>>> as you see: LAYERS=rt_ofc.10k54
>>>>> This is the GetLegendGraphic url created by QGIS:
>>>>> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc&map_resolution=91&language=ita&version=1.3.0&service=WMS&request=GetLegendGraphic&sld_version=1.1.0&layer=rt_ofc&format=image/png&STYLE=default&&TRANSPARENT=true
>>>>> NOTE: layer=rt_ofc
>>>>> (all seen in the debug info on QGIS on Linux (Debug)):
>>>>> Which SHOULD be:
>>>>> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc&map_resolution=91&language=ita&version=1.3.0&service=WMS&request=GetLegendGraphic&sld_version=1.1.0&layer=rt_ofc.10k54&format=image/png&STYLE=default&&TRANSPARENT=true
>>>>> NOTE, I edited: layer=rt_ofc.10k54
>>>>> Mmm, not much of an legend, but as least NOT an image of all (vector)
>>>>> layer legends...
>>>>> So crux is: IF a layer parameter has a dot in it's name, only the first
>>>>> part is used as parameter....
>>>>> BUT: what is the GetLegendGraphic url advertised by the server:
>>>>> Mmm, actually no style/LegendURL advertised :-(
>>>>> https://github.com/qgis/QGIS/blob/master/src/providers/wms/qgswmsprovider.cpp#L249
>>>>> points to pickLegend:
>>>>> https://github.com/qgis/QGIS/blob/master/src/providers/wms/qgswmsprovider.cpp#L227
>>>>> which looks ok:
>>>>> BUT apparently it picks the style of the PARENT-NODE of the layer: THAT
>>>>> one has
>>>>> <OnlineResource xlink:type="simple"
>>>>> xlink:href="http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmsofc&map_resolution=91&language=ita&version=1.3.0&service=WMS&request=GetLegendGraphic&sld_version=1.1.0&layer=rt_ofc&format=image/png&STYLE=default"/>
>>>>> style and legend.
>>>>> I think what QGIS does is 'inheriting' default styles from parent nodes.
>>>>> In this case that is plain wrong.
>>>>> Copy/paste this in an QGIS issue?
>>>>> Maybe for the getLegend url, the style should not be inherited?
>>>>> Anybody other ideas?
>>>>> Regards,
>>>>> On 03-09-16 16:08, Andrea Peri wrote:
>>>>>> Hi Richard.
>>>>>> Effectivelly I tested your wms and using it the legend is correctly
>>>>>> retrieved only for the layer choose.
>>>>>> I use qgis 2.16.1.
>>>>>> After I re-test my original url:
>>>>>> (this)
>>>>>> And again I see the qgis retrieve ALL the legend of all the layers.
>>>>>> I tested other wms of our set of wms service and seem only this has
>>>>>> that problem.
>>>>>> So I do some more proof tested.
>>>>>> And found where is the ISSUE.
>>>>>> QGIS wrong to get the legend when the layer wms requested HAS NOT A
>>>>>> LEGEND.
>>>>>> Infact the issu happened when I ask any layer of our wms that is a
>>>>>> RASTER LAYER with no legend defined.
>>>>>> Instead not happened when the layer wms is of a vector dataset (where
>>>>>> the legend happened).
>>>>>> SO If you whould test and see the issue you should use our wms service:
>>>>>> and choose the layer
>>>>>> rt_ofc.1954
>>>>>> that return the orthophoto imagery of the year 1954.
>>>>>> With this layer the qgis will retrieve ALL the legends of the wms
>>>>>> service.
>>>>>> Instead if you choose the layer
>>>>>> rt_ofc.1954.qu
>>>>>> that is a vector dataset (quadre of union)
>>>>>> qgis correctly retrieve only its own legend.
>>>>>> Please can you confirm this ?
>>>>>> Thx
>>>>>> A.
>>>>>> 2016-09-03 9:51 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
>>>>>>> On 31-08-16 21:10, Andrea Peri wrote:
>>>>>>>> Hi,
>>>>>>>> I notive that in the qgis 2.14.5 and in the qgis 2.16.1
>>>>>>>> when adding a layer wms choosing from a list of layers available in
>>>>>>>> the wms service connected,
>>>>>>>> qgis retrieve as legend of the layer ALL the legends of all the wms
>>>>>>>> layer available in the wms service.
>>>>>>>> Using the 2.8 QGIS version, the legend is retrieve correctly (only the
>>>>>>>> layer choosed).
>>>>>>>> Someone can confirm this as an issue ?
>>>>>>> Hi Andrea,
>>>>>>> nope, I have 2.16.1 here, and for example this wms:
>>>>>>> https://geodata.nationaalgeoregister.nl/bestuurlijkegrenzen/ows?SERVICE=WMS&
>>>>>>> I can choose either provincies or landsgrenzen (provinces or country
>>>>>>> borders), from that same server and both have their own legend.
>>>>>>> Do you have a WMS url for which this happens for you?
>>>>>>> What if you look at the capabilities of that service and do the
>>>>>>> getLegendGrapicRequest by hand. Is it also wrong?
>>>>>>> Else: create a good issue, with url's screendumps etc etc
>>>>>>> Regards,
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andrea Peri
>> qwerty àèìòù
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
