[mapserver-users] styling point shapefile for wms
jmorgan3
jmorgan3 at uwf.edu
Thu Apr 13 18:29:27 PDT 2017
Hello,
I am attempting to set up a basic MapServer environment and finding
myself such at what I think is a styling through WMS issue. I am finding
if I call up a WMS via the following URL I get the expected results
http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wq/wq.map&layer=wq_stations&mode=map
However, if I call the same WMS using
http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wq/wq.map&SERVICE=WMS&map=/ms4w/apps/wq/wq.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=wq_stations&CRS=EPSG:4326&BBOX=-87.6,30.00,-87.26,31.00&STYLES=&WIDTH=600&HEIGHT=600&FORMAT=image/png
I get a blank page. Perhaps in the first URL I am not actually using
WMS, but I am thinking the issue is more to do with how I setup or
incorrectly my STYLE. Here is my map file for reference:
# Start of map file
MAP
NAME WQ
STATUS ON
SIZE 600 600
EXTENT -87.6 30.00 -87.26 31.00
#EXTENT -87.60 28.67 -82.65 31.07 # [minx] [miny] [maxx] [maxy]
IMAGETYPE PNG
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
DEBUG 5
PROJECTION
"init=epsg:4326"
END
WEB
# change the next two lines to match your setup
IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
WMS_TITLE "WQ Demo"
WMS_ABSTRACT "This is WQ Demo"
WMS_ENABLE_REQUEST "*"
WMS_ACCESSCONSTRAINTS "none"
# change this value to match your setup
WMS_ONLINERESOURCE
"http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wq/wq.map"
WMS_SRS "EPSG:4326"
END
END
#Circle symbol
#Ref:
http://osgeo-org.1560.x6.nabble.com/Can-t-draw-points-from-shapefile-td5070300.html
SYMBOL
NAME 'CIRCLE'
TYPE ellipse
FILLED true
POINTS
1 1
END
END
# Start of layer definitions
LAYER
NAME "wq_stations"
DATA 'data/ewqma_stations4326.shp'
STATUS ON
TYPE POINT
CLASS
STYLE
SYMBOL 'CIRCLE'
COLOR 255 1 1
END
END # CLASS
END # LAYER
END # LAYER
END # Map File
Any pointers on what I am doing or interpreting incorrectly would be
greatly appreciated.
Thanks,
Derek
