[mapserver-users] Issue in using MapServer WFS Filter
Kajod Sharma
kajod4u at yahoo.com
Wed Apr 26 07:32:03 PDT 2017
Hi Steve,
Thanks for your response.
I have already tried with supplying SRS name in query. Now tried again, but results are still same.
Do you/someone know if I can somehow remove default spatial filter applied while MapServer makes a call to PostGIS?
Thanks. Regards,
Kajod
To: Kajod Sharma <kajod4u at yahoo.com>
Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Sent: Wednesday, 26 April 2017 3:05 PM
Subject: RE: [mapserver-users] Issue in using MapServer WFS Filter
Try adding &srsName="EPSG:4326"as a parameter
typeName=SampleLayer&srsName=EPSG:4326
De : Kajod Sharma <kajod4u at yahoo.com>
A : "mapserver-users at lists.osgeo.org"<mapserver-users at lists.osgeo.org>
Date : 2017-04-26 09:43
Objet : [mapserver-users]Issue in using MapServer WFS Filter
Envoyé par : "mapserver-users"<mapserver-users-bounces at lists.osgeo.org>
Greetings!
I hope this is a right platform to discussmy query regarding FILTER applied on MapServer WFS.
I'm new in this area and exploring some featuresof MapServer. I want to use GetFeature request of WFS to get features appliedon any location on map. I'm using "MapServer version 7.0.4 (MS4W 3.2.1)"and trying to apply filter "Contains" for it.
I can see two problems when it applies Filterquery on PostGIS:
1. It looks it adds an extradefault geospatial filter in it while making a query to PostGIS. This defaultspatial filter is not stopping to return any result from PostGIS. Is thereany way to exclude this default filter?
2. It seems Contains coordinatesare not transformed properly according to SRS of data in PostGIS.
I've tries with different projection in mapfile and request message with no success.
Supporting data to give your input on myqueries:
WFS request
Formatted Version:
http://localhost/cgi-bin/mapserv.exe?
service=WFS&
map=C:/Data/MapServerWFSSample.map&
request=GetFeature&
version=2.0.0&
FILTER=<Filter xmlns="http://www.opengis.net/ogc"xmlns:gml="http://www.opengis.net/gml"xmlns:ms="http://mapserver.gis.umn.edu/mapserver">
<Contains>
<PropertyName>wkb_Geometry</PropertyName>
<gml:Point srsName="urn:ogc:def:crs:EPSG::4326">
<gml:coordinates>0.112034,53.567972</gml:coordinates>
</gml:Point>
</Contains>
</Filter>
PostGIS query [Could see in log file]:
msPostGISLayerWhichShapes query: select "Attribute1","Attribute2","Attribute3",encode(ST_AsBinary(ST_Force2D("wkb_geometry"),'NDR'),'hex')as geom from SampleGeoDataTable where wkb_geometry&& ST_GeomFromText('POLYGON((-0.999462804873474 -1.00102606014116,-0.999462804873474-1.00102606014116,-0.999462804873474 -1.00102606014116,-0.999462804873474-1.00102606014116,-0.999462804873474 -1.00102606014116))',find_srid('','SampleGeoDataTable','wkb_geometry'))and (st_contains(wkb_geometry,ST_GeomFromText('POINT (7853690.3631838141000000-5506204.5232773330000000)'))= TRUE)
Similar WFS query to GeoServer works perfectly.
It would be very helpful if someone can helpme on it. Thanks a lot in advance.
Map File looks like:
MAP
NAME "Sample_WMS"
CONFIG "PROJ_LIB" "C:\ms4w\proj\nad"
CONFIG "MS_ERRORFILE" "C:/Data/ms_tmp/ms_error.txt"
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
STATUS ON
PROJECTION
"init=epsg:27700"
END
WEB
IMAGEPATH "C:/Data/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wfs_enable_request" "*"
"wfs_title" "MyGlobal Map WFS Server"
"wfs_srs" "EPSG:4326EPSG:900913 EPSG:27700"
"wfs_boundingbox" "EPSG:27700749.099975585938 -90036.5 660460.875 1227306.5"
END
END
LAYER
NAME "SampleLayer"
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:27700"
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost port=5432 dbname=SampleGeoDataTableuser=postgres password=hahaha"
DATA "wkb_geometry from SampleLayer"
CLASS
STYLE
COLOR 0 100 255
OUTLINECOLOR 0 0 0
END
END
METADATA
"wfs_title" "SampleWFS"
"wfs_srs" "EPSG:27700EPSG:4326 EPSG:900913"
"gml_include_items" "all"
END
END
END
Regards,
Kajod_______________________________________________
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170426/d9972e38/attachment.html>
