[mapserver-users] Error with Filter = no results
Daniel Hardes
hardes at 3dis.de
Thu Feb 2 01:19:46 PST 2017
Same query without srsName. I tried it with WFS 1.0.0, 1.1.0, 2.0.0 and
no results.
Am 02.02.2017 um 09:33 schrieb Rahkonen Jukka (MML):
> What happens if you remove srsName from the filter? It can be hard to know how to reproject from EPSG:32632 into unknown. WFS 1.0.0 is anyway tied to the default srs. I would also consider saving data into PostGIS with proper SRID.
> -Jukka Rahkonen-
> ----- Alkuperäinen viesti -----
> Lähettäjä: "Daniel Hardes" <hardes at 3dis.de>
> Lähetetty: 2.2.2017 10:22
> Vastaanottaja: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> Aihe: [mapserver-users] Error with Filter = no results
> Hello,
> i have a question with the Filter parameter.
> without a filter, mapserver does a normal SQL query like:
> select "pkid","set","id","lod","type","source","referencepoint","boundingbox",encode(ST_AsBinary(ST_Force_2D("groundsurface"),'NDR'),'hex') as geom,"id" from building where groundsurface && ST_GeomFromText('POLYGON((691642.41999 5334989.72599,691642.41999 5335172.82301,691979.17301 5335172.82301,691979.17301 5334989.72599,691642.41999 5334989.72599))',-1) limit 101
> but if i add an BBox filter, i got a wrong polygon:
> select "pkid","set","id","lod","type","source","referencepoint","boundingbox",encode(ST_AsBinary(ST_Force_2D("groundsurface"),'NDR'),'hex') as geom,"id" from building where groundsurface && ST_GeomFromText('POLYGON((-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785,-0.999888179649133 -0.999999999990785))',-1) and (st_intersects(groundsurface,ST_GeomFromText('POLYGON ((691813.1405204038600000 5335101.3663145527000000, 691813.1405204038600000 5335921.3585226759000000, 692960.5523786536700000 5335921.3585226759000000, 692960.5523786536700000 5335101.3663145527000000, 691813.1405204038600000 5335101.3663145527000000))',-1)) = TRUE)
> ... The polygon:
> is wrong. A normal SQL query without these values, gets my desired result.
> My map File:
> MAP
> NAME "sample"
> SIZE 800 400
> DEBUG 5
> OUTPUTFORMAT
> NAME "geojson"
> DRIVER "OGR/GEOJSON"
> MIMETYPE "application/json; subtype=geojson"
> FORMATOPTION "STORAGE=stream"
> FORMATOPTION "FORM=SIMPLE"
> END
> CONFIG MS_ERRORFILE "ms_error.log"
> PROJECTION
> "init=epsg:32632"
> END
> WEB
> METADATA
> ows_enable_request "*"
> END
> END
> LAYER
> DEBUG 5
> NAME "poly"
> STATUS DEFAULT
> TYPE POLYGON
> METADATA
> "wfs_srs" "EPSG:32632"
> "wms_transparent" "true"
> "wfs_getfeature_formatlist" "geojson"
> END
> PROJECTION
> 'init=epsg:32632'
> END
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost port=5432 user=postgres password=xxxxx dbname=map_daniel"
> DATA "groundsurface from building using SRID=-1 using unique id"
> CLASS
> STYLE
> COLOR "#88888888"
> ANTIALIAS true
> END
> END
> END
> END
> And the Request:
> http://localhost:8081/cgi-bin/mapserv.exe?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRSNAME=EPSG:32632&TYPENAMES=poly&COUNT=100&outputformat1=geojson&map=C:\Users\d.hardes\Documents\map.map&Filter=<Filter><BBOX><PropertyName>poly</PropertyName><Box srsName="EPSG:32632"> <coordinates>691813.1405204039,5335101.366314553 692960.5523786537,5335921.358522676</coordinates></Box></BBOX></Filter>
> And result
> <?xml version='1.0' encoding="UTF-8" ?>
> <wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://mapserver.gis.umn.edu/mapserver http://localhost:8081/cgi-bin/mapserv.exe?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=poly&OUTPUTFORMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:null>missing</gml:null>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> where is the Error in my settings?
3DIS GmbH <http://www.3dis.de>
Daniel Hardes
Mail: hardes at 3dis.de <mailto:kalkofen at 3dis.de>| Tel.: +49 (0)2861 8919 84
3DIS GmbH
Konrad-Zuse-Straße 6 D - 46397 Bocholt
www.3dis.de <http://www.3dis.de>
3DIS GmbH | Geschäftsführung: Gerrit Hoven, Andreas Steffens |
Amtsgericht Coesfeld | HRB 12986
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170202/d8a0b66e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170202/d8a0b66e/attachment-0001.png>
