[mapserver-users] Cant get polygon labels to show up
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Feb 14 08:09:41 PST 2017
Jukka,
Yes, this is the problem. I suspect that it is interpreting the '/' as
the start of a regex or something. I could not find a way to escape it
like '\/' or "\/".
I think this is a bug, I'll open a ticket for it.
I have worked around the problem by using OGR to add a column and
populate it with just the filename and not the long path.
-SteveW
On 2/14/2017 7:08 AM, Rahkonen Jukka (MML) wrote:
> Hi,
> I have located the problem into line
> WRAP '/'
> Perhaps slash requires escaping or something.
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Brent Fraser
> Lähetetty: 14. helmikuuta 2017 6:15
> Vastaanottaja: Stephen Woodbridge <woodbri at swoodbridge.com>; mapserver-users <mapserver-users at lists.osgeo.org>
> Aihe: Re: [mapserver-users] Cant get polygon labels to show up
> Try using
> CLASS
> TEXT '[LOCATION]'
> LABEL
> instead of LABELITEM?
> Best Regards,
> Brent Fraser
> On 2/13/2017 8:46 PM, Stephen Woodbridge wrote:
>> As a Followup, I used a hex editor to change the column name to
>> uppercase and that did not change anything so its not a case probelm
>> as far as I can tell.
>> -SteveW
>> On 2/13/2017 10:32 PM, Stephen Woodbridge wrote:
>>> On 2/13/2017 3:19 PM, Basques, Bob (CI-StPaul) wrote:
>>>> try lowercase “location” for the LABELITEM . . .
>>> Yeah, I tried that also. The tileindex file was created by gdaltindex
>>> and a hexdump on the .dbf does show it is lowercase. This is running
>>> on mapserver 7.0.4.
>>> I have tried everything I can think of at least twice but can't get
>>> it to label or throw any error message.
>>> I'm wondering if something in mapserver 7.0 changed in regards to
>>> matching shapefile DBF columns. At any rate I would expect some kind
>>> of error if there is a problem.
>>> I can provide the shapefile if someone is interested in checking it out.
>>> This one has me totally stumped.
>>> -Steve W
>>>> bobb
>>>>> On Feb 13, 2017, at 2:17 PM, Stephen Woodbridge
>>>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>>> I have a tileindex for a bunch of DOQQs and I would like to create
>>>>> a layer the displays there filenames and bboxes. I'm using the
>>>>> tileindex shapefile as my data source like with the layer definition below.
>>>>> The BBox polygon lines are showing up but I must be doing something
>>>>> stupid because I can not get the labels to display. And there are
>>>>> no errors in the log file.
>>>>> Any ideas?
>>>>> LAYER
>>>>> NAME "doqq_bbox"
>>>>> STATUS ON
>>>>> TYPE POLYGON
>>>>> DATA "ca_naip_2014_quads/doqq-tileindex"
>>>>> PROJECTION "init=epsg:4326" END
>>>>> LABELITEM "LOCATION"
>>>>> PROCESSING "LABEL_NO_CLIP=ON"
>>>>> CLASS
>>>>> STYLE
>>>>> OUTLINECOLOR "#ff0000"
>>>>> WIDTH 0.5
>>>>> END
>>>>> LABEL
>>>>> FONT "arial"
>>>>> TYPE TRUETYPE
>>>>> SIZE 14
>>>>> WRAP '/'
>>>>> ALIGN CENTER
>>>>> POSITION CC
>>>>> COLOR "#880000"
>>>>> OUTLINECOLOR "#ffffff"
>>>>> OUTLINEWIDTH 3
>>>>> PARTIALS TRUE
>>>>> FORCE TRUE
>>>>> END
>>>>> END
>>>>> END
>>>>> This email has been checked for viruses by Avast antivirus software.
>>>>> https://www.avast.com/antivirus
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> “There is nothing quite so useless as doing with great efficiency
>>>> something that should not be done at all.”
>>>> - Peter Drucker
