[mapserver-users] "Custom" GeoTIFF EPSG values not working
Richard Greenwood
richard.greenwood at gmail.com
Thu Feb 16 12:32:35 PST 2017
Your gdalinfo listing shows:
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",0],
whereas your in-line definition has:
"lat_0=90"
"lat_ts=70"
"lon_0=-45"
which looks fishy.
On Thu, Feb 16, 2017 at 7:44 AM, Cechini, Matthew F. (GSFC-423.0)[Science
Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov> wrote:
> Richard,
> Thanks for your reply. I looked into gdal versions and did see that I
> was running 1.11.1 vs 1.11.4 in a couple different places. When I run
> gdalinfo 1.11.4, I get the following output:
> PROJCS["WGS 84 / NSIDC Sea Ice Polar Stereographic North",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Polar_Stereographic"],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3413"]]
> And it doesn’t matter whether I have this:
> PROJECTION
> "init=epsg:3413"
> END
> or this:
> PROJECTION
> "proj=stere"
> "lat_0=90"
> "lat_ts=70"
> "lon_0=-45"
> "k=1"
> "x_0=0"
> "y_0=0"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> END
> at the top of my mapfile. In both cases, I have this in the LAYER
> definition:
> PROJECTION
> "init=epsg:3413"
> END
> It does not appear that mapserver is using the key/value items provided
> in the output PROJECTION definition.
> Thanks,
> Matt
> Matthew Cechini
> Contractor, Science Systems and Applications, Inc.
> NASA GIBS Systems/Software Engineer
> 410.205.6272 <(410)%20205-6272>
> From: Richard Greenwood <richard.greenwood at gmail.com>
> Date: Wednesday, February 15, 2017 at 9:24 PM
> To: Matthew Cechini <matthew.f.cechini at nasa.gov>
> Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> Subject: Re: [mapserver-users] "Custom" GeoTIFF EPSG values not working
> You should probably first get it sorted with gdalinfo before messing with
> mapserv. So you're doing gdalinfo on exactly the same file on your old and
> new systems and getting those results? What version of gdal on the two? Use
> "gdalinfo --version" and what type of file is it? Does it have an
> accompanying world file? If so, what happens if you hide the world file?
> Regarding your inline projection definitions in your map file, they are
> canceling each other out. The definition at the "top" of your file is the
> projection that your map fill be served out in. The definition within a
> LAYER block tells mapserv what projection that layer is in. So if the layer
> is different than the map, then mapserv will transform it, but if they are
> the same then mapserv does no transformation.
> On Wed, Feb 15, 2017 at 8:07 AM, Cechini, Matthew F. (GSFC-423.0)[Science
>> Once upon a time we were able to request GeoTIFF imagery through
>> mapserver and have gdalinfo report the following as the coordinate system:
>> PROJCS["unnamed",
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> PARAMETER["latitude_of_origin",70],
>> PARAMETER["central_meridian",-45],
>> UNIT["metre",1,
>> AUTHORITY["EPSG","9001"]]]
>> We’ve since changed to a new environment and version of mapserver (7.0.1
>> on Centos), and cannot get back to this capability. We now see this, which
>> is the CS for the source imagery:
>> LOCAL_CS["WGS 84 / NSIDC Sea Ice Polar Stereographic North",
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> AUTHORITY["EPSG","3413"],
>> UNIT["metre",1]]
>> I’ve tried to override it by adding the following PROJECTION definition
>> at the top of our mapfile as well as in the relevant LAYER, but that
>> doesn’t seem to do the trick.
>> PROJECTION
>> "proj=stere"
>> "lat_0=90"
>> "lat_ts=70"
>> "lon_0=-45"
>> "k=1"
>> "x_0=0"
>> "y_0=0"
>> "ellps=WGS84"
>> "datum=WGS84"
>> "units=m"
>> "no_defs"
>> END
>> Thoughts?
>> Thanks,
>> Matt
>> Matthew Cechini
>> mapserver-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170216/70455c74/attachment-0001.html>
