[mapserver-users] "Custom" GeoTIFF EPSG values not working
Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
matthew.f.cechini at nasa.gov
Tue Feb 21 05:50:09 PST 2017
Once upon a time we were able to request GeoTIFF imagery through mapserver and have gdalinfo report the following as the coordinate system:
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Polar_Stereographic"],
PARAMETER["latitude_of_origin",70],
PARAMETER["central_meridian",-45],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
We’ve since changed to a new environment and version of mapserver (7.0.1 on Centos), and cannot get back to this capability. We now see this, which is the CS for the source imagery:
LOCAL_CS["WGS 84 / NSIDC Sea Ice Polar Stereographic North",
GEOGCS["WGS 84",
DATUM["WGS_1984",
AUTHORITY["EPSG","3413"],
UNIT["metre",1]]
I’ve tried to override it by adding the following PROJECTION definition at the top of our mapfile as well as in the relevant LAYER, but that doesn’t seem to do the trick.
PROJECTION
"proj=stere"
"lat_0=90"
"lat_ts=70"
"lon_0=-45"
"k=1"
"x_0=0"
"y_0=0"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
Thoughts?
Thanks,
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170221/1012a7fa/attachment.html>
