[mapserver-users] Road shields on Mapserver 7
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Feb 24 08:07:06 PST 2017
Hello,
Thank you everyone for your help. I was able to get road shields to display. I do have a couple follow up questions:
First,
In the legend, the shield covers up the US Highway line. Is there a way to remove the shield from the legend, or make it the shield smaller on the legend than it is on the map?
Second,
I would like the roads to be labeled several times alternating between the street name and road shield. For example, the road shield should be placed at positions 0, 500, 1000 and the road name should be placed at positions 250, 750, 1250. I know that I could use REPEATDISTANCE to repeat the labels every 500 pixels, but is there something similar to INITIALGAP that will place the road name at an 250 pixel offset along the line?
I should mention that I was able to cheat by text every 250 pixels, and the shield every 500 pixels. This works because the text does not draw at positions 0, 500, 1000 because of the label conflict with the road shield, however I was wondering if there is a cleaner way to alternate labels between the street name and road shield.
Sincerely,
Mark Volz,
From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Sent: Thursday, February 23, 2017 1:57 PM
To: Mark Volz <MarkVolz at co.lyon.mn.us>; bfraser at GeoAnalytic.com; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Road shields on Mapserver 7
You certainly can have STYLEs inside labels. I use this to do shields on county roads:
CLASS
NAME 'County Road'
STYLE
COLOR 255 255 255
WIDTH 1 MAXWIDTH 1.5 MINWIDTH .75
OUTLINECOLOR 200 200 200
OUTLINEWIDTH 1
END
LABEL
STYLE # shield
SYMBOL 'county_road'
COLOR 255 255 255
OUTLINECOLOR 146 146 146
SIZE 13 MINSIZE 13 MAXSIZE 13
WIDTH .5 MINWIDTH .5 MAXWIDTH .5
END
PRIORITY 1
TYPE TRUETYPE
FONT 'myriad_condensed_web'
SIZE 5 MINSIZE 5 MAXSIZE 5
COLOR 146 146 146
MINDISTANCE 150
ANTIALIAS TRUE
PARTIALS FALSE
MINFEATURESIZE 20
END
END
Where county_road is referencing a true type font glyph. I'm actually doing some other conversions to remove dependency on ANNOTATION layers and haven't run into any problems yet. Perhaps the problem isn't with the style placement in the label but rather the contents of the style. You'd get a parse error otherwise.
Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Thursday, February 23, 2017 1:48 PM
To: bfraser at GeoAnalytic.com<mailto:bfraser at GeoAnalytic.com>; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Road shields on Mapserver 7
Brent,
I think your right. I was under the impression that STYLE could be within a LABEL object because since Mapserver 6.2 we could have multiple labels per class.
Anyways, how can I add road shields in Mapserver 7? Apparently annotation layers have been removed.
Thanks!
Sincerely,
Mark Volz, GISP
From: Brent Fraser [mailto:bfraser at GeoAnalytic.com]
Sent: Thursday, February 23, 2017 1:39 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>; Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>>
I don't think you can put a STYLE inside a LABEL. You could put it after the LABEL...
From: "Mark Volz" <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>>
Sent: Thursday, February 23, 2017 12:32 PM
To: "bfraser at GeoAnalytic.com<mailto:bfraser at GeoAnalytic.com>" <bfraser at GeoAnalytic.com<mailto:bfraser at GeoAnalytic.com>>, "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Brent,
I am using Mapserver 7.0.4.
Sincerely,
Mark Volz, GISP
Sent: Thursday, February 23, 2017 12:17 PM
Subject: re: [mapserver-users] Road shields on Mapserver 7
version of Mapserver?
Sent: Thursday, February 23, 2017 10:50 AM
To: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [mapserver-users] Road shields on Mapserver 7
Hello,
I am having trouble adding road shields to my map. The label (and for that matter the entire class) quits drawing as soon as I uncomment the STYLE block under label. Please let me know What I can do to add road shields to my roads layer.
CLASS
NAME "U.S. Highway"
EXPRESSION "A10"
STYLE
WIDTH 5
COLOR 0 0 0
END #STYLE
STYLE
WIDTH 3
COLOR 227 159 2
END #STYLE
LABEL
TEXT '[ROADNUM]'
SIZE 10 #for AGG
FONT vera_sans #for AGG
MINFEATURESIZE 25
MINDISTANCE 200
#STYLE ### Mapserver quits drawing this layer as soon as I uncomment this block
#SYMBOL './symbols/USHWY.png'
#END STYLE
END #label
END #class
P.S. Eventually I will want to display both the road number shield and the road name as well.
Thank You
Sincerely,
Mark Volz, GISP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170224/b61822a1/attachment.htm>
More information about the MapServer-users
