[mapserver-users] Define an End-Time attribute in WMS Time
Leroux, Alexandre (EC)
alexandre.leroux at canada.ca
Mon Feb 27 08:01:00 PST 2017
Hi all,
Related to this discussion, there's the OGC Best Practice for using Web Map Services (WMS) with Time-Dependent or Elevation-Dependent Data: http://www.opengis.net/doc/bp/wms-tnz/1.0
Regards -- Alex
Alexandre Leroux, M.Sc., ing.
Senior geospatial specialist /
Sp?cialiste principal en g?omatique
Data, Performance and Standards Section /
Section des Donn?es, performance et standards
Meteorological Service of Canada /
Service m?t?orologique du Canada
Environment and Climate Change Canada /
Environnement et Changement climatique Canada
alexandre.leroux at canada.ca<mailto:alexandre.leroux at canada.ca> - (514) 421-5024
On 02/27/2017 02:26 AM, Andrea Peri wrote:
I see it.
You have right infact I could define something like:
wms_dimensionlist: = start_date, end_date
wms_start_date_item= time
wms_end_date_item= time
wms_start_date_extent= "1900/01/01"
wms_end_date_extent= "2999/01/01"
wms_start_date_default=current
wms_end_date_default=current
This could be a solution on wms server side, but on client side it
need to have a wms client able to understant wms-dimension.
Actually my client interface is able to recognize and use a wms-time
but not able to recognize and use correctly a wms-dimensional from
getcapabilities.
A.
2017-02-27 7:48 GMT+01:00 Emanuele Di Giacomo <edigiacomo at arpae.it><mailto:edigiacomo at arpae.it>:
Hi Andrea,
if you need two datetime attributes for each feature (in your example,
for each county), you can use custom dimensions
http://mapserver.org/ogc/wms_dimension.html.
Emanuele
On Sun, Feb 26, 2017 at 6:32 PM, Andrea Peri <aperi2007 at gmail.com><mailto:aperi2007 at gmail.com> wrote:
Hi Jeff.
I was understanding the wms_timeextend as defined in the annex C3 of OGC.
AFAIK it is the domains of availability for the values in the
time-field in all the dataset
But is always one only attribute. This is ok for spot events. Instead
when there is a dataset where every feature is a start-date and an
end-date of validity for every single feature of dataset.
As example:
the dataset of county boundaries. Sometime the county bounaries could
change so they have a startdate and an enddate.
So is need to define both: the end-date and the start-date using two
attribute fields.
I wrong to understand the wms_timeextend ?
Thx,
A.
2017-02-26 17:29 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com><mailto:jmckenna at gatewaygeomatics.com>:
Hi Andrea,
The possible WMS Time parameters for MapServer are documented at:
http://mapserver.org/ogc/wms_time.html There is a "wms_timeextent"
parameter that sets the possible start/end time range, but I am not sure if
I am understanding your question fully.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2017-02-26 11:58 AM, Andrea Peri wrote:
I need to define a WMS Time for using on an our dataset.
But I need colud define also a End-Time attribute. Because a single
feature has a
start-time validity and an end-time validity.
Searching for some workaround on internet, I see that this option
(start-time and end-time of validity for a feature) is allowed in
geoserver.
http://docs.geoserver.org/latest/en/user/data/webadmin/layers.html#data-webadmin-layers-edit-dimensions
So I hope it could be done also possible in mapserver.
Thx.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty ?????
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170227/e501f625/attachment.html>
