[mapserver-users] Label position not as expected version 7.0.x
thomas bonfort
thomas.bonfort at gmail.com
Tue Jan 3 04:22:25 PST 2017
correct. the position of "center of the text" varies depending on whether
your glyphs have ascenders and/or descenders, and thus produces
inconsistent centering between "aaa", "ppp" or "bbbb".
This can be easily reverted by commenting out the two special cases for CR
and CL at
https://github.com/mapserver/mapserver/blob/rel-7-0-3/maplabel.c#L989 .
replace with
y1 = (h/2.0) + oy;
thomas
On Mon, Jan 2, 2017 at 6:58 PM Ian Walberg <ian.walberg at airborne.aero>
wrote:
> Thomas.
> Hmm, I do not understand why the change was made from the older versions.
> So the vertical ‘center’ position is actually align the text baseline with
> the point position and not the ‘center’ of the text as previously?
> Regards
> Ian
> *From:* thomas bonfort [mailto:thomas.bonfort at gmail.com]
> *Sent:* Monday, January 2, 2017 9:41 AM
> *To:* Ian Walberg <ian.walberg at airborne.aero>;
> mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Label position not as expected version
> 7.0.x
> Ian,
> It's the intented effect, with the label baseline aligned with the symbol
> baseline. You can probably nudge it manually with an offset if you need to.
> thomas
> On Mon, Jan 2, 2017 at 6:30 PM Ian Walberg <ian.walberg at airborne.aero>
> wrote:
> Folks,
> Happy New Year to everyone.
> Using version 7.0.x we are not seeing the label positon as we had for
> previous versions for mapserver.
> The vertical label position now appears to not center naturally on the
> text but is towards the bottom of the center line.
> Are we missing something?
> Thanks
> Ian
> MAP
> EXTENT 0.0 0.0 10.0 10.0
> SIZE 1024 720
> IMAGECOLOR 140 140 140
> SYMBOL
> NAME 'City'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED true
> END
> LAYER
> NAME "Label position"
> TYPE POINT
> STATUS DEFAULT
> FEATURE
> POINTS
> 1.00 5.00
> 1.00 8.00
> END # POINTS
> END # FEATURE
> CLASS
> TEXT 'Label text'
> STYLE
> SYMBOL 'City'
> SIZE 12
> COLOR 255 255 255
> END # STYLE
> LABEL
> TYPE BITMAP
> SIZE 30
> COLOR 255 255 255
> POSITION CR
> END # LABEL
> END # CLASS
> END # LAYER
> END # MAP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170103/10e0857e/attachment-0001.html>
