[mapserver-users] variable substitution
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Jan 4 17:24:19 PST 2017
I should also add that you should add anchors (^$) to your validation expression. Just using "[0-9]" will match "111" but also "111; do something nasty in SQL". So "^[0-9]*$" is much better.
Steve
________________________________________
Sent: Wednesday, January 04, 2017 9:01 AM
To: Stephen Woodbridge; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] variable substitution
Actually you don't want the []'s around the substitution as they denote a column reference. '%adrkey%' or %adrkey% should suffice depending on the type of comparison being done. --Steve
From: mapserver-users [mapserver-users-bounces at lists.osgeo.org] on behalf of Stephen Woodbridge [woodbri at swoodbridge.com]
Sent: Wednesday, January 04, 2017 8:53 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] variable substitution
Or use:
FILTER ( "[gid]" = '[%adrkey%]' )
" for the column name
' for the value
-Steve W
On 1/4/2017 6:47 AM, thomas bonfort wrote:
> yeah, if you want an integer comparison use:
> FILTER ( [gid] = [%adrkey%] )
> On Wed, Jan 4, 2017 at 12:43 PM Jörg Thomsen (WhereGroup)
> <joerg.thomsen at wheregroup.com <mailto:joerg.thomsen at wheregroup.com>> wrote:
> Hello Thomas,
> Am 04.01.2017 um 12:34 schrieb thomas bonfort:
> > FILTER ( "[gid]" = "[%adrkey%]" )
> this doesn't work, ms puts the value into quotes so PG interprets it as
> a column-name.
> > [Wed Jan 4 12:40:04 2017].714496 msPostGISLayerWhichShapes():
> Error (ERROR: column "2" does not exist
> > LINE 1: select
> "beschriftung","gid","2",encode(ST_AsBinary(ST_Force2...
> But the Filteritem / Filter solution is ok.
> Viele Grüße,
> Jörg Thomsen
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> https://www.foss-academy.com/schulungstermine/kompaktkurs-winterschule
> Jörg Thomsen
> WhereGroup GmbH & Co. KG
> Gillweg 3
> 14193 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74 <tel:+49%2030%20513027874>
> Fax: +49 (0)30 / 89 09 53 21 <tel:+49%2030%2089095321>
> www.wheregroup.com <http://www.wheregroup.com>
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
