[mapserver-users] Mapserver data point on map
Carlos Ruiz
boolean10001 at yahoo.com
Fri Jan 6 10:13:55 PST 2017
If you have PIXMAP symbols defined in your MAP file, be sure to assign them to the points by adding the following in your code:
$style->set("symbolname", "<PIXMAP_SYMBOL_NAME>");
I remember that when adding points in a static MAP file I have to add a POINTS 1 1 END symbol for the points to be drawn. Perhaps this is what is happening to you.
Best regards
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170106/4d3f1045/attachment-0001.html>
