[mapserver-users] Mapserver seem change the line size in raster dataset
Andrea Peri
aperi2007 at gmail.com
Fri Jan 13 14:11:04 PST 2017
Hi Jukka.
This is a direct getmap over our wms
http://www502.regione.toscana.it/ows2/com.rt.wms.RTmap/wms?map=owstopoweb&version=1.3.0&map_resolution=91&TRANSPARENT=true&LAYERS=rt_topoweb.800k.rt&STYLES=&CRS=EPSG:25832&SERVICE=WMS&REQUEST=GetMap&FORMAT=image/png&BBOX=563561.9927077,4809257.3212631,817953.27072102,4878814.3834541&WIDTH=1302&HEIGHT=356
The raster is setting with this layer mapfile:
OUTPUTFORMAT
NAME "AGGA"
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA #serve RGBA per avere il trasparente
FORMATOPTION "GAMMA=0.75"
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "COMPRESSION=6" # Compression: 0=no compression,
9=best, 6=default compression
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_COLORS=256"
TRANSPARENT ON
END
LAYER
NAME "rt_topoweb.800k.rt"
STATUS OFF
EXTENT 1530000 4665000 1800000 4950000
TYPE raster
TILEINDEX '/path-to-shapefile indexfile/index_tiled'
TILEITEM 'location'
PROJECTION
"+init=epsg:3003"
END
PROCESSING "BANDS=1,2,3"
PROCESSING "NODATA=0"
PROCESSING "LOAD_WHOLE_IMAGE=YES"
PROCESSING "RESAMPLE=AVERAGE"
PROCESSING "OVERSAMPLE_RATIO=4.0"
# ... other standard raster processing functions here
METADATA
"wms_title" "TopoWEB 800k"
"wms_extent" "1530000 4665000 1800000 4950000"
"wms_abstract" "Carta Topografica in scala 1:25.000"
"wms_layer_group" "/rt_topoweb.rt"
END
MAXSCALEDENOM 5000000
MINSCALEDENOM 600000
# the color index for transparent
OFFSITE 0 0 0
# the global opacity (100=full opaque)
OPACITY 100
END
2017-01-13 11:17 GMT+01:00 Rahkonen Jukka (MML)
<jukka.rahkonen at maanmittauslaitos.fi>:
> Hi,
> What is included in "any setting I know on mapserver"? Could you show a link to some raster, together with the LAYER from your mapfile?
> -Jukka Rahkonen-
> Hi, I have a raster dataset to publish on internet using mapserver wms.
> This dataset is a rasterization of some thematic datasets.
> After publish it, I notice a difference between the map returned from mapserver and reproduced on qgis and the map reproduced using qgis accessing directly the same raster.
> I try any setting I know on mapserver but without be able to obtain the same image.
> To show the diffrence I capture the screenshot of both as visible on qgis:
> This is the sample of the raster on qgis retrieve from mapserver wms:
> https://www.dropbox.com/s/464cg3c91b5twpz/from-mapserver-scale800000.gif?dl=0
> This instead is the sample of the raster on qgis retrieve directly from the raster accessed directly from qgis.
> https://www.dropbox.com/s/ai9p3ntnkcmp9zt/from-qgis-scale800000.gif?dl=0
> The colors are the same, the difference is in the lines. That qgis desktop version has the lines more defined instead the mapserver version has lines reduced.
> Any hint is welcome,
> Thx
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
Andrea Peri
qwerty àèìòù
