[mapserver-users] 3D / 2.5D / Coordinates with Z and GEOMETRY Type in WFS
Michael Smith
michael.smith.erdc at gmail.com
Tue Jul 4 13:57:15 PDT 2017
Is it something we should even consider removing as a compile time option? Perhaps at an v8 release?
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
> On Jul 4, 2017, at 4:46 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Before this past long weekend I was testing with Windows and getting about a 1% difference; but I didn't report it here because I was using the 'wallclock' time and not CPU time, on Windows. (that was with Even's 200 map draw test) I personally feel that the difference is so minimal now that yes, we should enable SUPPORTS=POINT_Z_M for the next MS4W release.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
>> On 2017-07-03 4:49 AM, Daniel Hardes wrote:
>> Do we need more testing or could "USE_POINT_Z_M = ON" the default in the next release?
>>> Even Rouault <even.rouault at spatialys.com> hat am 30. Juni 2017 um 16:40 geschrieben:
>>> On vendredi 30 juin 2017 09:59:30 CEST Daniel Morissette wrote:
>>> > On 2017-06-30 9:50 AM, Even Rouault wrote:
>>> > > I'm wondering if we shouldn't revisit the decision to have USE_POINT_Z_M
>>> > > disabled by default. This is often annoying.
>>> > > Apparently, adding USE_POINT_Z_M defaulting to OFF was driven by
>>> > > performance reasons per
>>> > > https://github.com/mapserver/mapserver/issues/1244 . But this was 12
>>> > > years ago. Perhaps with recent hardware the performance difference isn't
>>> > > that big. The ticket unfortunately doesn't contain a test case to bench
>>> > > (likely lots of lines/polygons, or large lines/polygons to render). If
>>> > > the perf difference is still there, a more involved change would be
>>> > > indeed to move the z and m components into separate arrays.
>>> > #1244 refers to #1224 which is using the gmap demo mapfile... which is a
>>> > relatively small dataset, so it should be easy to verify if the issue is
>>> > still relevant on more recent hardware using gmap or probably any other
>>> > dataset.
>>> > https://github.com/mapserver/mapserver-import/issues/1224
>>> OK, I downloaded
>>> http://dl.maptools.org/dl/gmap-ms46.tar.gz
>>> (not sure if there's a more uptodate version of it).
>>> Added the necessary MAP and SYMBOLSET keywords in the mapfile and symbolset file.
>>> With master, compiled in Release (-O3)
>>> and the following Python mapscript bench.py
>>> import mapscript
>>> for i in range(200):
>>> map = mapscript.mapObj('gmap75.map')
>>> img1 = map.draw()
>>> I ran it 10 times consecutively with each config and took the smallest time ("real" figure)
>>> With USE_POINT_Z_M=OFF
>>> time python bench.py
>>> real 0m4.167s
>>> user 0m3.964s
>>> sys 0m0.200s
>>> With USE_POINT_Z_M=ON
>>> real 0m4.252s
>>> user 0m3.972s
>>> sys 0m0.260s
>>> So USE_POINT_Z_M=ON is 2% slower than OFF
>>> On a recent (~ 1 year old) laptop with a
>>> Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
>>> Even
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
