[mapserver-users] 3D / 2.5D / Coordinates with Z and GEOMETRY Type in WFS
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Mon Jul 10 10:09:40 PDT 2017
Maybe to mapserver-dev for a discussion? Could apply the patch (https://github.com/mapserver/mapserver/pull/5456) to 7.2.
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Tuesday, July 04, 2017 4:05 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] 3D / 2.5D / Coordinates with Z and GEOMETRY Type in WFS
Or leaving the compile time option but enabling it by default? (maybe
we are saying the same thing ha)
-jeff
On 2017-07-04 5:57 PM, Michael Smith wrote:
> Is it something we should even consider removing as a compile time option? Perhaps at an v8 release?
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
>> On Jul 4, 2017, at 4:46 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> Before this past long weekend I was testing with Windows and getting about a 1% difference; but I didn't report it here because I was using the 'wallclock' time and not CPU time, on Windows. (that was with Even's 200 map draw test) I personally feel that the difference is so minimal now that yes, we should enable SUPPORTS=POINT_Z_M for the next MS4W release.
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>>> On 2017-07-03 4:49 AM, Daniel Hardes wrote:
>>> Do we need more testing or could "USE_POINT_Z_M = ON" the default in the next release?
>>>> Even Rouault <even.rouault at spatialys.com> hat am 30. Juni 2017 um 16:40 geschrieben:
>>>> On vendredi 30 juin 2017 09:59:30 CEST Daniel Morissette wrote:
>>>>> On 2017-06-30 9:50 AM, Even Rouault wrote:
>>>>>> I'm wondering if we shouldn't revisit the decision to have USE_POINT_Z_M
>>>>>> disabled by default. This is often annoying.
>>>>>> Apparently, adding USE_POINT_Z_M defaulting to OFF was driven by
>>>>>> performance reasons per
>>>>>> https://github.com/mapserver/mapserver/issues/1244 . But this was 12
>>>>>> years ago. Perhaps with recent hardware the performance difference isn't
>>>>>> that big. The ticket unfortunately doesn't contain a test case to bench
>>>>>> (likely lots of lines/polygons, or large lines/polygons to render). If
>>>>>> the perf difference is still there, a more involved change would be
>>>>>> indeed to move the z and m components into separate arrays.
>>>>> #1244 refers to #1224 which is using the gmap demo mapfile... which is a
>>>>> relatively small dataset, so it should be easy to verify if the issue is
>>>>> still relevant on more recent hardware using gmap or probably any other
>>>>> dataset.
>>>>> https://github.com/mapserver/mapserver-import/issues/1224
>>>> OK, I downloaded
>>>> http://dl.maptools.org/dl/gmap-ms46.tar.gz
>>>> (not sure if there's a more uptodate version of it).
>>>> Added the necessary MAP and SYMBOLSET keywords in the mapfile and symbolset file.
>>>> With master, compiled in Release (-O3)
>>>> and the following Python mapscript bench.py
>>>> import mapscript
>>>> for i in range(200):
>>>> map = mapscript.mapObj('gmap75.map')
>>>> img1 = map.draw()
>>>> I ran it 10 times consecutively with each config and took the smallest time ("real" figure)
>>>> With USE_POINT_Z_M=OFF
>>>> time python bench.py
>>>> real 0m4.167s
>>>> user 0m3.964s
>>>> sys 0m0.200s
>>>> With USE_POINT_Z_M=ON
>>>> real 0m4.252s
>>>> user 0m3.972s
>>>> sys 0m0.260s
>>>> So USE_POINT_Z_M=ON is 2% slower than OFF
>>>> On a recent (~ 1 year old) laptop with a
>>>> Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
>>>> Even
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
>> mapserver-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Jeff McKenna
